  3. help on Layer operation command
  • Subscribers 152
  • Views 15613
lrl12skdev
lrl12skdev over 16 years ago
 Hi evryone,
I am trying to do an AND operation between two layers and one posibility is that the other layer could be in a lower hierarchy of the layout.
I have already tried to use leLayerAnd and dbLayerAnd but they both can't operate with layers on different hierarchy. I tried also to use dbGetOverlaps but I got only a nested list and not an output drawing in my cellview. I am making the skill for IC5.1.41
Is there anyone who knows a work-around procedure?
 regards,
  • Quek
    Quek over 16 years ago
    Hi Irlsk
    Please see COS solution 11237840 for a script on hierarchical layer operations.
    Best regards
    Quek
  • lrl12skdev
     Hi Quek,
     Thanks again for your fast reply. I will try it out today. I'm sure it will be Ok since it must be around for sometime already.
     best regards,  -lrlsk
  • lrl12skdev
    Hi Quek
     I have tried already the solution from your post but there is a minor issue that I have encountered. The one with UI works perfectly but the other method (calling the procedure with arguments in skill) seems not.
    Anyway, I think I can already do something out from it, since I also need to change the procedure to apply only within a specified bBox.
    Many thanks again.
     BR  -rence
