  3. Pass variable from Skill script to Perl script
  • Views 15133
Khurana
Khurana over 16 years ago
How can I pass a variable (value) from a Skill script to a Perl script (calling Perl script from within the Skill script)?
Varun
    Hi Varun,
    How are you invoking the Perl script? You could pass a variable either on the command line to the perl script, or by creating a UNIX environment variable (using the SKILL function setShellEnvVar()), or you could create a file which the perl script reads. Many ways, and hard to advise which without knowing more details.
