  3. Sorting ADE variables and outputs
  • Views 17320
edogd
edogd over 16 years ago
In my ADE enviroment, I tend to end up with many variables and outputs.  ADE does not these lists and when you have a lot of variables and outputs it gets hard to find the one you are looking for.  So I wrote a small script to sort the lists,  but in order to see the results I have either: Save state and reload it to see sorted variables and outputs. Or create and then delete a dummy variable or output to update variables and outputs lists. Does anyone know how to update those lists in the ADE windows without doing the work around I mentioned?
Here is my code for sorting:
 cs=window(30)->sevSession ; Get session by using its window number
qq=copy(cs->variables) ; Get copy of variables
; Sort the variables
rr=sort( qq 'lambda( ( a b ) ( strcmp( a->name  b->name ) <= 0 ) ) )
; Renumber the variable index
cntr=1
foreach( x rr
       x->index=cntr
       cntr++
cs->variables=rr
qq2=copy(cs->outputs) ; Get copy of outputs
; Sort the outputs
rr2=sort( qq2 'lambda(
               ( a b )
               ; use non-nil fields for strcmp
               if( a~>name != nil
                 then name1 = a~>name
                 else if( a~>signal != nil
                    then name1 = a~>signal
                    else name1 = expression
               if( b~>name != nil
                 then name2 = b~>name
                 else if( b~>signal != nil
                    then name2 = b~>signal
                    else name2 = expression
               ( strcmp( name1  name2 ) <= 0 )
; Renumber the output index
cntr=1
foreach( x2 rr2
       x2->index=cntr
       cntr++
cs->outputs=rr2
    Which version are you using? This is a standard feature in IC614 - you can sort and also manually reorder using drag and drop.
    I have some code to reorder the outputs for earlier releases but it uses private SKILL functions so I don't want to publish it here. I don't think you can do what you want without using private functions.
    So, if you're using an IC6 based release, moving to IC614 would be the easiest solution!
  • edogd
     I am using IC51.  It's unfortunate, that IC51 functions are still being kept private.   We won't be using IC6 for a while, we are too heavily entrenched with IC51.
    It's not a matter of the functions being "kept private". The vast majority of SKILL that runs in IC5141 will also work in IC61 too. If we make a function public in IC5141, it puts the onus on Cadence to ensure that the function continues to be supported in IC61X releases as well. This means that we cannot change those functions, we need to document all those functions, and so on.
    So it's a practical trade off, I'm afraid.
    That said, I'm happy to provide the code to you as an individual, provided that it is used with care and not used beyond its expected life (i.e. no need to use it in IC614). Please log a service request via support.cadence.com and ask the AE to contact me and I'll provide the code. I just don't want to post it here as it's then effectively documenting the functions for all.
    Best Regards,
  • edogd
    Thank you for the honest response.  There are many good features in IC6 that as an engineer we would love to use; however, it'll be a slow migration.
    In the mean time, I'll ask our Cadence coordinator to send in the service request as you detailed below.
    Again thank,
    E.D.
