  3. environment variables
  • Subscribers 152
  • Views 17082
Michael Robinson
Michael Robinson over 16 years ago
While looking at the reference for leHiCreateVia, I found a reference for the environment variable to control the Mode: envSetVar("layout" "viaMode" 'cyclic "Auto"). What is the environment variable for the Check Same Net checkbox?
  • berndf
    berndf over 16 years ago
     My way of figuring out what env. var. correspond with a
    specific UI setting.
    1. Save default .cdsenv to a specifc name e.g. cdsenv1
    2. Modify UI setting
    3. Save new .cdsenv to a new name e.g. cdsenv2
    4. Do a file diff between cdsenv1 and cdsenv2
       The difference will be the env. var. reflecting the UI
       modification.
    Best is to use
     - All possible tools
     - All tool variables
     - Overwrite
    as options to save the .cdsenv.
    Bernd
  • Michael Robinson
    That worked.
    I found what I was looking for.
    Thanks.
    Michael Robinson 970-225-7501
    National Semiconductor michael.robinson@nsc.com
    > modification.
    > Best is to use
    > - Overwrite
    > Bernd
    > You received this email because you subscribed to notifications for
    > the Cadence Custom IC SKILL Forum. To unsubscribe, log in, go to
    > forums, and change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
