  3. move instances of a pcell in the whole design
  • Views 15893
nuSkill
nuSkill over 15 years ago
Hi, I have an existing layout and I changed the pcell type of the resistors used, the problem is the pcell origin of the original is different from the new one. I can replace them just fine, but all instances are shifted once I update it. Is there a way in skill to move all instances of the new pcells on my entire layout library? Perhaps a shift commnad or something? Below is a clip of how I replace the pcell.
 if( inst~>cellName == "res_old" then
    leReplaceAnyInstMaster( inst "new_library" "res_new" nil )
    ;; shift the instance position code here???
 Appreciate any help.
/Andal
    You'll need to iterate over all instances (maybe using the instHeaders for efficiency):
    foreach(instHeader cvId~>instHeaders
      when(instHeader~>cellName=="res_new" && instHeader~>libName=="new_library"
        foreach(inst instHeader~>instances
          dbMoveFig(inst cvId list(-0.6:0.2 "R0")  ; or whatever transformation needed
    Something like that.
  • nuSkill
    Hi Andrew, Thank you very much for your suggestions and sorry for the delayed reply. I actually kinda found some solution for my problem whis is by manipulating the inst~>xy property of the instance. I just need to figure out the math for the delta x and delta y transformation. It seems I must consider the inst~>orient property as well in order to achieve the original position of my instances after replacement.
    Again thank you very much for your support.
    /Andal
