  3. How to compare 2 float variable/numbers?
  • Subscribers 152
  • Views 3092
raams
raams over 15 years ago
Below code reads the  float value from a given txt file and compares it with another float value calculated using equation below.
If loop is not executing for the below mentioned code though the two variables "nspace" and "vspace" are equal
input file has following line:
net tt space= 0.15
code:
procedure(match()
in=infile("~/nets.txt")
when(in
while(gets(line in) && line!="NULL"
linelist=simStringsToList(line)
nspace=atof(nth(3 linelist))
a=0.16
b=0.16
x1=0.715
x2=1.025
vspace=abs(abs(x1-x2)-(a/2)-(b/2))
if(vspace==nspace then println("correct") else println("wrong") )
output:
wrong
can anyone pls let me know the error in the above code?
Thnx
  • StefanSL
    StefanSL over 15 years ago
    Hi raams,
    as almost expected, your problem seems to be related to the internal representation of floats;
    two floats being displayed as the same number must not necessarily be the same number cause
    they are cut behind the 7th decimal:
    (in the CIW, define x=0.15 and add 0.0001, 0.00001 and so on;
    if you add 0.0000001, you'l  get 0.1500001,
    if you add 0.00000001,the result will be 0.15
    depending on the way they are calculated, nspace and vspace seem to be different
    more or less far behind the decimal-point;
    after rounding the result looks as initially expected:
    nspace=float( round( 100000 * vspace ) ) /100000
    vspace=float( round( 100000 * vspace ) ) /100000
    println(nspace)
    println(vspace)
    if(nspace==vspace then println("correct") else println("wrong") )
    will get a "correct"
    if you are interested in very small differences, this might not be applicable,
    but perhaps it will help you...
    kind regards
    Stefan
