  3. automatic netlist
  • Views 15986
automatic netlist
AMSboston
AMSboston over 15 years ago
I have an extracted view.
I then go to ADE and netlist. I then save the netlist in a particular directory which is different from the default location.
Assuming I have an open extracted view, is there a way to netlist from the CIW by running a skill script where I would type:
netlistSkill("dir").
The "dir" is where the netlist will be stored.
Any help will help:)
Dan.
    Dan,
    The closest is to use OCEAN functions:
    simulator('spectre)
    design("libName" "cellName" "viewName")
    createNetlist()
    And then copy the netlist (using system("cp ...") maybe) to where you want. The above will put it in the normal ADE directory structure - you could use envSetVal("asimenv.startup" "projectDir" 'string "/path/to/where/you/want/the/root/to/be") to alter that, but it will still create the ADE directory structure underneath - you can't directly netlist into a specific directory with the OCEAN functions.
    You could wrap all the above in your own function definition to make it simpler of course.
    Best Regards,
  • AMSboston
    Andrew,
    Makes sense.
    Dan.
