  3. Assura DRC/LVS/RCX batch run with SKILL
  • Subscribers 152
  • Views 3241
Karagyaurov
Karagyaurov over 15 years ago
Can somebody please explain how to start Assura DRC/LVS/RCX with a SKILL script? I need to run these checks on an entire library with cells and I have no idea about hot to make a batch run.
10x a lot!
  • Quek
    Quek over 15 years ago
    Hi Karagyaurov
    You can use the following perlscript. It runs Assura LVS and QRC on an entire library. I think it is more convenient to use perl for this case. The idea is the same using SKILL. You would have to write out the appropriate rsf files for DRC and LVS and also the ccl cmd file for QRC using SKILL. The files can then be run using cmds such as "system("assura mydrc.rsf")".You will have to modify the perlscript a little to include DRC run.
    Best regards
    Quek
    • genRC.txt
  • Karagyaurov
    Hi Quek,
    10x a lot!
    I think that this script would really do what I need.
    In the meantime I started writing my own in bash, but the command you gave - system("assura mydrc.rsf") will allow me to write it skill also.
    Best regards!
    Karagyaurov
