  3. how can i create a table in the form
  • Views 16750
jeef
jeef over 15 years ago
hi all,
I would like to create a table in the form which can be edited like EXCEL, I try to use the TreeTable,but it can't be edited,
can you give me some advice, thank you
    There's no support for an editable table field. You should contact customer support so that an enhancement request can be filed (although R&D said a while ago that there was no plan for this - but if you don't ask, you won't get ;-> )
  • rajeshcad
    rajeshcad over 15 years ago
    If you take a look at Placer- > Pin Placement form in VLS-XL,  it uses a report field for displaying a list of pins. And then it has a set of corresponding editable fields on the form where you can do changes and click on "apply" to implement the chnages to a given pin ( or a row of record ).
    I think this is the closest possible if I am thinking correctly as to what you want.
