  3. Open config view schematic through skill
  • Subscribers 150
  • Views 18671
markbeck
markbeck over 15 years ago
 I'm trying to figure out how to open a config view schematic.
I can use deOpenCellView("Lib" "cell" "config" "config"), but that gives me a popup which I then have to click 'ok' before the config schematic opens.
I can use hiFormDone(hiGetCurrentForm()) to make the popup go away, but it's causing me scripting headaches and it's quite kludgey. I'd much rather directly open the config schematic.
deOpen and geOpen give me similar behavior.
Does anyone out there know how to do this?
    The trick is the configL slot in the fileSpec argument to deOpen. For example:
    *  DISCLAIMER: The following code is provided for Cadence customers to use at  *
    *   their own risk. The code may require modification to satisfy the           *
    *   requirements of any user. The code and any modifications to the code may   *
    *   not be compatible with current or future versions of Cadence products.     *
    *   THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT     *
    *   LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    *   OR FITNESS FOR A PARTICULAR USE.                                           *
    procedure(abOpenConfiguredSchematic(confLib confCell confView mode)
      let((hdb libName cellName viewName fileSpec)
        ; Find the top view from the config
        hdb=hdbOpen(confLib confCell confView mode)
        libName=hdbGetTopLibName(hdb)
        cellName=hdbGetTopCellName(hdb)
        viewName=hdbGetTopViewName(hdb)
        hdbClose(hdb)
        ; Build the filespec for deOpen
        fileSpec=list(nil)
        fileSpec->libName=libName
        fileSpec->cellName=cellName
        fileSpec->viewName=viewName
        fileSpec->accessMode=mode
        fileSpec->configL=list(confLib confCell confView mode)
        deOpen(fileSpec)
    You'd call this function with the name of the config view, and it will open the top level schematic using that config.
    Best Regards,
  • markbeck
     Excellent. I thought I had tried using the configL in the fileSpec before, but I must have done something wrong.
    I had just found another 'kludgy' way to get a similar results, before checking the website:
    w_window = hiOpenWindow()
    geOpen(?window w_window ?lib t_lib ?cell t_cell ?view "schematic" ?viewType "schematic")
       when( hdbIsConfig(t_lib t_cell "config")
          h_config = hdbOpen(t_lib t_cell "config" "r")
          deSetConfigId(w_window h_config) ; set window's config
       ); when
    But your method is more what I was looking for.
    Thanks!
  • rajeshcad
    rajeshcad over 15 years ago
    Andrew,
    You would like to put this SKILL code in a solution if not already..
    Rajesh
    Rajesh,
    Will do.
