  3. access monte-carlo data ?
  • Views 14725
MohEllayali
MohEllayali over 15 years ago
hello everybody,
I have a problem with monte carlo simulation, i use for this an ocean script
after running the monte carlo simulation ( one iteration, one seed, saveData set to true ), i am interested in the waveform which comes from it.
so what i do is(after monte carlo finishes successfully) :
selectResult('ac)
i check that all outputs are available by the outputs() commande
i am able to plot my waveform : for instance : plot (v("OUTM")) works fine
but when i want to do more processing i can't
for instance if i am interested in the value of my waveform at 1MHz, i do
value(v("OUTM") 1M), i get as a return value drwave:183029968 which is a waveform , not a value as i would expect.
is there any particular syntax if i want to access monte-carlo data
i use cadence IC5141
many thanks in advance
    It's a waveform, because it is giving you the value at 1M versus the iteration number. You could do a second value() around this to pick a value at a specific iteration number, or use value(v("OUTM") 'iteration 23) to get the waveform at at iteration 23 (and then do value(... 1M) on this.
