  3. Running a ocean script from perl
  • Subscribers 152
  • Views 15539
gurusub
gurusub over 15 years ago
 I would like to call an ocean script from perl to aid  automation. Is there a on-line command as in UNIX to accomplish the same?
In UNIX i would say %cat ocean_script.ocn|ocean.
I tried writing code for the cat function in perl and use the pipe to call the script, but it does not work rather it just prints the ocean script in the console which a traditional cat command in UNIX does. Seems like I am missing something important here.
Guru
  • berndf
    berndf over 15 years ago
     Can you do a
    sytem( ocean,  ocean_script.ocn )
    Bernd
  • gurusub
    Thanks Bernd it works. More precisely,
    system("ocean<ocean_script.ocn");
    Guru
