  3. adding quotation marks in a string - nesting strings
  • Views 2529
lperktold
lperktold over 15 years ago
 I would like to run a shell command and wait for it to finish before SKILL continues.
 Assume I want to delete a directory hirachically, (I didn't find a hirachically delete command in SKILL) by running
 ccmd = sprintf(strx "rm -r %s" run_directory)
 csh(ccmd)
Thid works fine, but SKILL is not waiting for the csh command to finish. So I tried to use the inter process communication capability of SKILL:
cid = ipcBeginProcess( strcat("csh(\"" ccmd "\")" ) )
ipcWait(cid)
This code does not give me any errors or warnings but does also not delte the directory. I guess the basic problem comes with nesting of  strings when running ipcBeginProcess(). The csh() command as well as the ipcBeginProcess() command expect a string as an argument. I tried to nest those two strings by using the quotation mark escape sequence. SKILL then produces a string like:
"csh(\"rm -r /simulation/320MHz_1.2V_27deg\")"
It seems like the csh() command is not capable of interpreting its given string correctly? But this is just a guess.
Would appreciate any comments.
Enjoy Lunch,
Lukas
    Not sure why csh("command") is not waiting (it does for me).
    With ipcBeginProcess, you want to do ipcBeginProcess("rm -rf dir" ...) and not a command like "csh(rm -rf ...)" because that's not a valid UNIX command.
  • lperktold
     Hello Andrew,
     I had a mistake in my ocean script. I tried to create a log file with outfile() right after I exectuted the csh("rm ...") command. I expected the outfile() command to create the missing directories which it does not. I interpreted this as SKILL not waiting for my csh() command to finish. - Sorry for that.
    So you were completely right Andrew - SKILL is waiting for the csh() command to exit and I don't need any icp command. Everything works now as expected.
    Thanks for your help. And for the future I will call ipcBeginProcess() directly with a shell command instead of a SKILL command :)
    Thaks again,
    Lukas
