  3. Problem with Pcell and its CDF
  • Subscribers 152
  • Views 15306
Renee
Renee over 15 years ago
    I tried to create a MOS transistor pcell using SKILL, and I had two problems with the pcell's CDF :
    I defined a Boolean parameter withTap in the pcell, and if withTap is true(t), then there will be taps in the layout of MOS transistor, vice versa.
    In the pcell.il file, I defined this parameter as below:
    (withTap t)
If(withTap then
    dbCreateRect(...)
In the CDF file, I defined this parameter as below:
    cdfCreateParam( cdfId
        ?name           "withTap"
        ?prompt         "Include Taps?"
        ?defvalue       "t"
        ?type           "boolean"
        ?display        "t"
But when I create instance with Edit Instance Property form, I found that it failed to response to this switch as if it failed to pass the value from the form to pcell layout.
Then I tried to define withTap as int, it worked this time.
Are there anything wrong with my definition of this parameter? Although it works with integer type as well, I still prefer it to be Boolean type.
The other problem is with my instantiation instances.
It is weird that when I try to instantiate an instance of this pcell, it still keeps the value of last instance. It seems that it stores its values every time I create an instance. Thus, I have to press Default button when I create a new instance using this pcell, and it is not quite convenient.
Is there any other way to solve this problem?
Any suggestions to solve this problem.
Thanks in advence
Renee
  • ifab
    ifab over 15 years ago
    I think I got an error before, doing something like this.
    Try defining the parameter value in the pcell code as:
        (withTap boolean t)
    Best Regards,
    I-FAB
  • Renee
    Thanks for your advice. I've solved the problem. :)
