  3. how to create window and send data to it
  • Subscribers 153
  • Views 17047
Trevor1981
Trevor1981 over 15 years ago
I'm new to skill and have probably a very simple issue with it. I need to create a window and send some data to it, so in short my code should do something like that:
w_id = hiOpenWindow( ...)
fprintf(w_id "blah blah")
fprintf(w_id "more blah blah")
Obviously, fprintf is not the right command for this task as it accepts 'port' type variable and not the window handle.
Does anyone know how to achieve it in SKILL? Thanks for your help.
 T.
  • lrl12skdev
    lrl12skdev over 15 years ago
    Hi trevor
    try using hiDisplayAppDbox.
    ex..                 hiDisplayAppDBox( ?name 'areabox ?dboxBanner "Polygon Area"
                                                           ?dboxText sprintf( nil,"The Polygon Area is %1.3f",totalarea )
                                                           ?dialogType hicInformationDialog ?buttonLayout 'Close )
    BR  -lrlsk
  • StefanSL
    StefanSL over 15 years ago
    Hi Trevor1981,
    here a piece of code based on a form containing a scrolled region and
    a string-field:
    ;first, create the field to print your message to
    mydout = hiCreateOutputStringField(?name 'mydout ?defValue "OUTPUT"
    ?invisible nil
    ; create a scrolled region, place mydout inside
    myds = hiCreateScrollRegion(
    ?name 'myds
    ?fields list( list(mydout 0:0 500:300) )
    ; create a form and place myds into it
    mydform = hiCreateAppForm(?name 'mydform ?fields list( list(myds 0:0 600:350 ) ))
    ; display the form
    hiDisplayForm(mydform)
    ; now you can write to the form by modifying mydform->myds->mydout->value :
    mydform->myds->mydout->value = "OUTTEXT01"
    ; or by just appending new text
    mydform->myds->mydout->value = strcat(mydform->myds->mydout->value "\n" "more outtext")
    slight problem: the scrolled field does not follow your input, could not
    find the correct usage of hiSetScrollBarValue:
    hiSetScrollBarValue(mydform list(0 1000))  (-> applied to the form,)
    behaves as expected (if there is a scrollbar on the form, just reduce the window-size to check)
    but executing hiSetScrollBarValue(myds list(0 1000))
    i run into a warning
    "drawing area is NULL!" and scroll-position doesn't change
    so, there's some more work to do but i hope this is a starting point for
    further steps.
    regards
    Stefan
  • Trevor1981
     Hi StefaSL
    Thanks for the code. The text input is not appended correctly, I mean I see it in somehow the middle of the form window instead of being appended at the lower line. I will work on it though to have it fixed.
    Thanks again for the reply.
