  3. Virtuoso Corners Analysis SKILL commands
  • Views 16292
fishbulb15
fishbulb15 over 15 years ago
1) I am trying to write some SKILL code to copy measurements from the outputs list to the corner's  measurements list.  Whenever I startup a new ADE session then load the state and then open the corner's tool, the corner's tool loads the measurements automatically.  Is there a commad or set of commands to tell the corner's java tool to refresh those measurements?
 2) After I enter in information with the cor* or load[P|D]cf commands is there a command that will refresh the corner's window to show the updates?
 3)  The command asiGetCornerList(asiGetCurrentSession()) returns a nil after being executed instead of printing out the different corner objects.Below is the information of the data for that session, the javaCornersProcess = t.  Where is all the corner's data located or how can I access it in SKILL?
\i asiGetCurrentSession()~>data~>?
\t (events sessionDirName _nlComponentCount asiResultsDir mixedNetlistDir
\t     keepList forceNodes translatedStimulusFileList netlistStatus rawNetlistSt\t     corPrintWindows projectDir digitalHostMode designVarOK context
\t     flowchart javaCornersProcess latestDataDir netlistDir designVarList
\t     cacheData asiConfigId asiGenericVarToEnvVarTable capTabForms designObj
\t     formatOptions netlistOptions stimulusData cornerList cellView
\t     dataMappingFuncs state childSessionList sevSession outputList
\t     id toolName tempModelSetup _netlistBypasFlag wasInterrupted
\t     marchList spPorts processPriority asiGraphicalParam env
\t     simControl controlFilesOK initConds functionNameMap analysis
\t     plotList designVarTable plotType computeData digitalHost
\t     stimulusGlobals dataAccessFuncs netlistFormatterClass files tempOK
\t     nodeSets stimulusInputs asiiOwner evaluateExprFlag
\t )
4) After a bit more digging I found the corCallJavaSkillEvents(arg1 arg2) command, but I do not know what are the two arguments are supposed to be.  Is there any reference for this?  Would this function be applicable?
    See my answer at /forums/p/16881/1179115.aspx#1179115
