  3. Saving snapshots of layout, schematic views
  • Subscribers 152
  • Views 19238
jalwyn
jalwyn over 15 years ago
I am trying to save the current layout/schematic which is being edited to a snaphot cadence library.This snapshot is taken at specific time intervals say every 10 minutes. I would retain 2 snapshots the latest one and the previous 10 minutes. I do not want to save the view being edited. I did write a skill code for this task, the skill code runs in the background and as able to create the snapshots. The problem was I could not undo(hiUndo()) some edits in the current cell view, as the the undo operation probably tried to undo the operations done by the background skill code. I am not sure if my understaning is correct. Can anyone please advice if there is a better way to handle this.
I am providing the skeleton of the skill code I wrote
 procedure(saveSnpSht()
 prog(()
  ;This procedure saves the existing snapshot to old snapshot and saves the
  ;current cell view as new snapshot
procedure(CCS_snpShot()
  hiRegTimer("saveSnpSht()  CCS_snpShot()" 6000)
I will execute  CCS_snpShot() in ciw, this keeps running in he background while I continue editing the cell view.
 Thanks and regards
John
  • Quek
    Quek over 15 years ago
    Hi John
    I am thinking that perhaps it might be better if you use make use of snapshot function from a typical file server (e.g. NetApp). It would be more efficient and the snapshot timings can be easily configured. I have not tried writing a skillscript to take snapshots but wouldn't that slow down Virtuoso since you plan to run it at 10mins interval? Even though you plan to run it in the background, I think executing a cmd at regular intervals would still have an effect on Virtuoso. Perhaps Andrew or Lawrence has better ideas on how to do it. : )
    Best regards
    Quek
  • skillUser
    skillUser over 15 years ago
     Hi John,
    I hope you are using IC61x as there are new capabilities ther, such as hiWindowSaveImage():
    hiWindowSaveImage(
      [?target g_target]
      [?path t_path]
      [?format t_format]
      [?toplevel g_toplevel]
      [?quality n_quality]
      [?delay n_delay]
      [?timeoutBeep g_timeoutBeep]
      => t | nil
    This lets you save an image to various formats such as PNG, BMP, JPEG etc.
    And in IC614 there is another related function that you might be interested in, hiGenerateThumbnails():
      ?lib g_lib
      [?cell g_cell]
      [?view g_view]
      [?sizes g_sizes]
      [?output g_output]
      [?verbose g_verbose]
      => thumbnails | nil
    This creates a 128x128 size PNG of the cellview in the cellview directory.
    If you are using IC514 then I think the options within the tools are limited, you might print/plot a cellview to a postscript file. The Tools->Camera utility calls "xcam" behind the scenes, so this may not be much different than what you were thinking originally?
    I hope that the above information helps,
    Lawrence.
  • jalwyn
    Hi Quek, Lawrence,
    Thanks for the infos you have provided.
    I use IC5141 will be moving to OA some time later.
    Let me explain the requirement in more detail
    1. By snapshot I meant saving the cadence files(all contents of cell/view dir)
    2. I do not intend to save the current cell view as the user will do it whenever he wishes to, the script running in background would save the view being edited in a seperate directory. In effect this would be something similar to saving mails in Drafts folder when the mail is being composed.The mail gets saved at regular intervals even if the user does not save it.
    The benefit of this approach is to recover data that user was working on sometime back.
    Use of unix snapshots or version control tools would need specific configurations, allocation of storage space etc..
    Also I guess all of that would be useful ony if user tries to save the view either manually saving it or using the autosave, autocheckin features.
    As mentioned earlier, I was not able to undo an edit done to layout probably because hiUndo() tried to undo one of the tasks done by the
    saveSnpShot() function running in the background as that was the operation that hiUndo() recognized.
    Is it possible to branch out the saveSnpShot() function as seperate process such that the tasks done by it do not interfere with users tasks.Would ipc help?
    Please let me know your comments.
    Thanks and regards
    John
