  3. Schematic versus schematic by using SKILL .
  • Subscribers 152
  • Views 20377
marbs
marbs over 15 years ago
 Hi All,
I need your help once more .
How can I make a SKILL program to compare two schematic from two
different library ? I want to display the differences of the two schematic
in a text file . I am using icfb version 5.1
Thanks in advance ,
Marbs
  • Quek
    Quek over 15 years ago
    Hi Marbs
    This is not really the answer that you are seeking but I would like to suggest using any lvs tool to do it (e.g. Assura or PVS). SVS (schematic vs schematic) is a standard function for lvs tools. It would really be take quite a complicated skillscript to do a hierarchical comparison and to output a proper report. : )
    Best regards
    Quek
  • skillUser
    skillUser over 15 years ago
    Hi Marbs,
    I agree with Quek that the best tools for SVS are often those traditionally also used for LVS (Diva, Dracula, Assura, PVS etc.)
    If you wanted to compare two schematics, what do you wish to compare?  The graphics? Or just the connectivity and parameter values? Just one schematic, or the hierarchy?  The answer to these questions would help determine the best method.  If it is the devices and their parameters, it is not too difficult to write a simple "netlister" that outputs the devices, their parameters and the connectivity, but how would you compare the two netlists?  This would not be trivial to write, hence the suggestion of using an SVS capable tool.
    Lawrence.
  • luvishis
    luvishis over 14 years ago
    Additional way to compare 2 schematics/netlists is to use EDIF schematic/EDIF netlist export from Virtuoso.
    There are companies like www.elgris.com that provide netlist  comparison utilities.
