  3. hiCreateAppForm without Scrollbars
  • Views 16278
Trevor1981
Trevor1981 over 15 years ago
 I have a (probably) simple question:
How to create an AppForm with hiCreateAppForm without horizontal and vertical scrollbars. I would like the AppForm window to be of a fixed size (non-adjustable) and no scrollbars visible.
I miss the options like ?hasVerticalScrollbar and ?hasHorizontalScrollbar.
Thank you for your answers.
T.
    Use the ?minSize and ?maxSize (set to the same) and then the form will not be resizable. Obviously you need to make it big enough that no scroll bars will be needed.
  • Trevor1981
     Works well! Thank you.
    T.
  • rajoli
    rajoli over 7 years ago in reply to Trevor1981
    How to change vertical scroll bar right to left?
    CSR
    Andrew Beckett over 7 years ago in reply to rajoli
    You can’t as far as I know. Also, please read the forum guidelines - they tell you not to post on the end of an old (8 years old in this case) thread.
