  3. How to edit schBindKeys.il file to highlight wire
  • Views 20866
jlbach
jlbach over 15 years ago
 I know in cadence if you press 9 or 0 one can highlight a wire or not highlight that wire respectively. The skill code I used was geAddNetProbe and geDeleteNetProbe. But why candence only highlight the wire label with colors, not the wire itself.
How can I make the whole wire to be highlighted in colors.
Thank you
  • Quek
    Quek over 15 years ago
    Hi jlbach
    geAddNetProbe seems to be working fine for me. Both wire and label are highlighted. I am using IC614-507. You can check the version of Virtuoso using:
    terminal>virtuoso -W
    Perhaps you might want to provide more info on your issue.
    Best regards
    Quek
  • bene86
    bene86 over 15 years ago
     I have a related problem. I can highlight wires by pressing 9 and the click on them but I cannot unhighlight them. 0 doesn't work for me. Do you know, why that could be?
     greets, bene
  • skillUser
    skillUser over 15 years ago
    Hi Bene,
    The "9" bindkey is defined by default in the schematic bindkeys file, but I don't think that "0" is; however you can add it easily using the Options -> Bindkey form (Set the Application to "Schematics", Enter "0" for the Key or Mouse Binding and "geDeleteNetProbe()" for the Command) from the CIW, or using SKILL:
     hiSetBindKey("Schematics" "<Key>0" "geDeleteNetProbe()")
    As to the previous issue of not highlighting the netbut only the label, I do not see this issue either.  Perhaps a Service Request could be filed for further investigation?
    Best regards,
    Lawrence.
  • Jim0318
    Jim0318 over 6 years ago in reply to skillUser
    Hi Lawrence
    I have a related problem. How to set Bindkey to unhighlight all the highlighted Nets? I have a try to set hiSetBindKey("Schematics" "<Key>!" "geAllDeleteNetProbe()")  or hiSetBindKey("Schematics" "<Key>!" "geDeleteAllNetProbe()"), but failed. PLS help me. Thanks
    Best regards,
    Jim Cao
  • skillUser
    skillUser over 6 years ago in reply to Jim0318
    Hi Jim,
    The bindkey setting needs to be made a little differently:
    hiSetBindKey("Schematics" "Shift<Key>1" "geDeleteAllNetProbe()")
    Best regards,
    Lawrence.
