  3. How to get the final box of MarkNet ?
  • Replies 7
  • Views 17180
Charley Chen
Charley Chen over 15 years ago
Dear All, After I use MarkNet command , it can highlight all the connectivity. Can I get the bBox of the MarkNet's result ? e.g. box = MarkNet() , to get box Thank you, Charley
    Charley,
    In IC614 you have Connectivity->Save All Mark Nets which allows you to save the marked nets to another cellView (as shapes). From that you could find the overall bounding box.
    I don't think it's possible any other way - in previous releases there was no way to get hold of the shapes returned by Mark Net.
  • Charley Chen
    Hi Andrew, Thank you for your information. I will try it. Thank you, Charley
  • Charley Chen
    Hi Andrew, I can use leHiMarkNet() to marknet , if it has 2 or 3 or ...net on the same point , (e.g. Net1's lpp is "ME4" ; Net2's lpp is "ME3" ; Net3's lpp is "ME6" ) How do I only get Net2 Marknet (which lpp is "ME3") ? Thank you, Charley
    If there are overlapping shapes at the point where you click with mark net, it only picks one of them. The workaround would be to turn off the visibility in the LSW or layer palette of the layers you don't want to pick, and then turn them back on again afterwards.The mark net trace will still follow invisible layers, but won't allow you to start from an invisible layer.
  • Charley Chen
     How do I purge the last result by using MarkNet ?
    Thank you,
    Charley
    Hi Charley,
    Connectivity->Net->Unmark net should do it, if I've understood your question.
  • Charley Chen
    It works.
    Thank you,
    Charley
