  3. IC 6.1.3 Iterated Names
  • Views 14598
Thodoros
Thodoros over 15 years ago
If I create an instance with name inst<0:15> then  16 instances are represented.
 Is there a way to create this way MxN instances?
Thanks in advance,
Thodoros
    No, at least not without using inst<0:Z> where Z is MxN-1. Only a single dimension is supported.
  • Thodoros
    OK, I solved it. I used a double iteration to create a 2d array.
    I ceated a col_inst that it iterates inst M times, and then I iterate that col_inst via a row_inst N times.
    Thodoros
