  3. How to turn off the check button of the Via Layers by skill...
  • Views 15006
How to turn off the check button of the Via Layers by skill ?
Charley Chen
Charley Chen over 15 years ago
Hi All,
I have viaDefs section in the technology file , I want to use them but when I launch leHiMarkNet,
Action : leHiMarkNet -> change "Via Layers used by Mark Net" to  "Select Via Layers" -> Click "Display Via Layers"
-> turn off the "Via Layer" you don't want ........)
 I only know the the name  ("DIFF" & "ME1" & " PO1") not connect
(DIFF CONT  ME1)   on -> off
(PO1 CONT ME1)  on -> off
Thank you,
Charley
    Charley,
    Your question was a bit confusing, but I think it's the same as enhancement request CCR 494984 - you want a means of being able to set the default via layers that are used, overriding what it finds by looking at the viaDefs in the tech file. Currently there's no way of doing this, as far as I know.
    I would suggest you log a service request with http://support.cadence.com and request this, so a duplicate CCR can be filed. This will increase the likelihood of this enhancement being implemented.
