  3. Deleting multiple shapes from a layout database
  • Views 18014
LeJonT
LeJonT over 15 years ago
I have a large flattened layout. I wanted to delete all the shapes covered by a shape drawn on a specific layer. I'm using a code similar to this:
custShapes = setof( shapes cellView~>shapes ( shapes~>lpp == ( "NAME" "PURPOSE" ) ) )
toBeDeletedObjs = setof( shapes cellView~>shapes isCovered( shapes custShape ) )
;isCovered(): checks whether the first shape is inside any of the other shapes in the second list
foreach( obj toBeDeletedObjs
  dbDeleteObj( obj )
) ;foreach
This is taking very long time since the number of shapes is very high. Strange thing is if I select all those objects in the layout editor and delete them by pressing the delete button, the deletion is almost instantaneous.
1. Is the any fast method to get the above thing done?
2. What is the method to delete a list of objects?
3. How will I get the list of all shapes completely covered by another shape or a list of shapes?
4. Is there any better way to achieve the above functionality?
foreach( obj geGetSelSet() dbDeleteObj( obj ) ) ;foreach
Why the above sentence is taking much longer than the press of a delete key?
  • skillUser
    skillUser over 15 years ago
    Hi Leo,
    The first statement can be replaced with a more efficient approach - you are iterating over all of the shapes to find those on a specific layer-purpose pair, another approach which is generally much more efficient is to iterate over the layer-purpose objects to find the one you're interested in, and then to get all of the shapes on that lpp.  Usually the number of shapes is one or more orders of magnitude larger than the number of lpps, so this is where you gain efficiency.  In code, it might look something like this:
      lpp = car(setof(lpp cellView~>lpps lpp~>layerName=="NAME" && lpp~>purpose=="PURPOSE"))
      custShapes = lpp~>shapes
      mapcar('dbDeleteObj toBeDeletedObjs)  ;; might be marginally more efficient than above code?
     I don't know about your "isCovered" algorithm, but this is being called while iterating over the list of all shapes, so this is likely to be an "expensive" step in the above flow.  For "isCovered" you might use the dbGetOverlaps() function to see if the "custShape" has any overlaps with another non-custShape shape? Then you only need to iterate over the custShapes list rather than all of the cellview shapes; use the output of dbGetOverlaps to determine if the current shape overlaps anything that is not on the custShapes list, if not return "t", otherwise "nil" (I'm guessing that this is what isCovered does).
    I hope this helps you.
    regards,
    Lawrence.
  • LeJonT
    Hi Lawrence,
    It really helped! The performance improvement achieved is in terms of tens of minutes.
    1. The number of lpps in my layout is close to a hundred while the number of shapes being few ten thousands. The performance increment that I had is significantly big; in terms of tens of minutes while I've used the suggested method for deleting the objects.
    2. isCovered: it accepts two inputs; [either a point and a bBox] or [two bBoxes]. It actually checks whether the first point/bBox is inside the second bBox. dbGetOverlaps() function cannot be a direct replacement for this functionality, I guess. Is there any function to achieve the above?
    Thanks a lot..
