  3. Perl TK
  • Subscribers 152
  • Views 16783
Perl TK
Khurana
Khurana over 15 years ago
I am calling a perl (TK) script using a menu pick inside a tool and the TK dialog pops up fine the first time the perl TK script is invoked after launching the tool, but subsequent invocations of the script do not pop up the TK window - any ideas as to what may be causing this
Here's the script:
#!/usr/bin/perl
use strict;
use warnings;
use Tk;
my $mw = MainWindow->new;
$mw->title("Hello World");
$mw->Button(-text => "Exit", -command => sub {exit})->pack;
MainLoop;
Varun
  • Khurana
    Since I am using a Skill script which calls the Perl script using ipcBeginProcess() looks like the problem is that the parent process (Skill script) keeps running and needs to be killed or stopped.  But, so far ipcKillProcess() has not worked...
    In your first post, you didn't even mention how you were launching the process.
    In your second you've given a faint glimpse of the details, but still not enough to give anyone a chance to help.
    Try to put yourself in the position of the reader of these posts. They do not have the benefit of knowing what's in your head, or even being able to see your code. Would you be able to answer a question under such circumstances?
    I don't mean to be rude, but many here are willing to help - but we can't perform miracles! We might be able to have a wild guess at what the problem is, but that's not a very efficient way of working, nor terribly likely to succeed.
    Kind Regards,
  • Khurana
    Andrew,
    Well, your reply was rude and impolite.  With this I am going to think twice about using the Cadence Custom IC Skill forum for help.
    If I haven't given sufficient details then what's the harm in asking for those details as supposed to giving your customer a lecture on how to use the forum...?
    Varun
    Hi Varun,
    Please accept my apologies if you were offended by my post or found it impolite. That was not my intention - I was trying to encourage you (and others) that by giving enough details you stand a much greater chance of getting an answer to your problem. I respond to posts on a completely voluntary basis in my free time - it is not part of my job at Cadence to do this. So I have to try to balance my time and so I am much more likely to spend time answering those where sufficient information has been provided. I dislike leaving any questions unanswered if others have not responded (see the amount of posts I have made) - but of course it's best for me personally if I don't have to go back and forth several times, especially when I'm often travelling and may be unable to respond for a few days.
    Anyway, that was not meant to be an excuse, and my previous response was not mean to be a lecture.
    If you can enlighten me as to precisely how you're  invoking the Perl/Tk application, which version of Virtuoso you're using and so on, it would really help. Maybe we can get to the bottom of the problem.
    I did just try using:
    id=ipcBeginProcess("perlGUI")
    id2=ipcBeginProcess("perlGUI")
    And I get two on the screen. If I use ipcIsAliveProcess(id) or ipcIsAliveProcess(id2) I get t, until I've hit the Exit button on the "perlGUI" program - at which point the ipcIsAliveProcess(id) etc returns nil, as I'd expect.
    I'm running using IC614 (6.1.4.500.8) - although I'd be surprised if that makes a difference.
    Having exited, I can run again and a new one will get launched.
  • babji
    babji over 15 years ago
     try "system" if you dont have to use ipcReadProcess.
  • Khurana
    I was able to get it to work using ipcWaitForProcess()
    Varun
