  3. CDF Parameters Recalculation
  • Views 18433
engSemi
engSemi over 15 years ago
Dear ALL,
How can I trigger the recalculation of the CDF parameters for a certain library?
    Look at https://support.cadence.com/apex/homePage
  • engSemi
    I received the fllowing error when loading the skill commands
    *Error* PasCdfGetDpt: argument #1 should be any user-defined (other) type (type template = "o") - CCSeffCDF@0xcd79d18
     any solution?
    You will need to call the function as:
     CCSinvokeCdfCallbacks(cvId ?callInitProc t ?useInstCDF t)
    The key part is the ?useInstCDF part, but if it's a PAS-generated PDK, it's quite likely that you may also need ?callInitProc t as well.
    Some PDKs you have to use the effective "lookalike" CDF approach (see the comments in the code), but others it is safe to use instance CDF instead.
    Best Regards,
  • engSemi
    Dear Andrew,
    It works, you saved my life :)
    Mohamed Samir
