  3. A problem with context file
  • Views 15794
Renee
Renee over 15 years ago
Hi
I define a procedure to select design layer when I draw layout as below:
procedure(metal1()
    leiMouseSetEntryLayer(6)
);end
hiSetBindKey("Layout" "<Key>1" "metal1()")
I save this file into context by:
setContext("current")
load "set_layer.il"
saveContext("set_layer.cxt")
 Then, in the .cdsinit file, I write
loadContext("set_layer.cxt")
But when I start icfb and open a layout, I could not get the layer metal1 when I press <Key>1 button. I have to reload set_layer.il file and it says that those functions have been loaded.
Since it says so, it means that the context file is loaded. However, why can I use the bindkey?
Thanks in advance!
Lei
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     I don't think that the context saves the assignmentof the bindkey. It only saves the procedure and variable definitions. You may want to put the bindkey assignment in the context init procedure which runs when the context is loaded.
