  3. SKILL program in distributed mode
  • Views 14891
fazul
fazul over 15 years ago
hi is it possible to run a SKILL code in the distributed mode ie to submit the code to run in the queue so that even if i close the icfb session (CIW window) SKILL program is not killed.? thanks in advance, Fazul
  • skillUser
    skillUser over 15 years ago
    Hi Fazul,
    I'm not sure about "queuing" a SKILL program up, but you could start an external job that would keep running if the current process is exited.
    Here's an example:
    ::: slow.il :::
    printf("Starting slow SKILL job\n")
    for(i 1 100
    sleep(5)
    printf("Slept for %d seconds, iteration %d\n" i*5 i)
    printf("End!\n")
    In the CIW:
    sh("dbAccess -load slow.il &") ;; <--- note the ampersand
    My example uses "dbAccess" but you could invoke another "virtuoso" here (e.g. in -nograph mode), depending on your needs, or if it is just pure core SKILL commands, then the "skill" executable would work (but it has a different invocation syntax).
    Hope this helps,
    Lawrence.
