  3. Easiest way to dump MonteExpr results in a file
  • Views 14511
gurusub
gurusub over 15 years ago
 I am running Monte Carlo sims and I use a lot of MontExpr commands to perform various calculation. I would like to dump all these calculated data into a file for post processing. What is the easiest way to do it?
 Guru
    If using IC5141, they already are dumped into a file "mcdata". You may find the SKILL code in this solution helpful though:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11026072
    If using ADE XL in IC61X, you can export the table of results (with "Detailed" selected) to a CSV file.
