  3. Problem with hierarchical layout design
  • Views 14632
Renee
Renee over 15 years ago
I tried to build a MOS pcell with this function:
I could change the length and width, or other property of MOS by stretching its layout, not by making changes to the CDF parameters. It seems that it contains a stretch handle.
I do not know how to add this stretching function to the pcell.
I tried to build a Guard Ring pcell with this function:
If Guard Ring A and Guard Ring B are put together, their contacts are overlapped which causes DRC violations.I tried to write a script that process these overlapped contacts and eliminate those violations.
But there is a problem with processing the layout of Guard Ring:
 I build the guard ring using rodCreatePath function. The contacts are part of the path. If I try to make changes to those contacts, I have to flatten that layout which I prefer not to do.
Is there any other way to build the guard ring(maybe not of path type)? Or, is there other way to edit the cell layout without flattening(edit-in-place function won't work for pcell, I've tried)?
Thanks in advance!!
Lei
  • skillUser
    skillUser over 15 years ago
     Hi Lei,
    You will want to use the SKILL function rodAssignHandleToParameter() in order to make the Pcell parameters into stretch handles. Search for this function and also "simplemos" in the documentation for a code example.  Also, your Cadence installation contains code examples which are documented in the "Sample Parameterized Cells Installation and Reference".
    For the overlapping guard rings, if you make the contacts choppable, but not the other parts of the guard ring structure you want to keep, then when you chop through the guard ring the contacts will be removed, but the non-choppable sub-parts will remain. This is a manual process, but at least it does not require the structure to be flattened.
    I hope that this answers your questions.
    Lawrence.
