  3. Assura Directory Creation
  • Subscribers 152
  • Views 18187
Patrick1982
Patrick1982 over 15 years ago
I'm new to Assura (in the past I used Hercules) and I have found the form quite annoying, so what I would like to is automatically load the Run Directory, while also create the Run Directory from cadence using the Library name and Cell Name.  So what I was think is creating a bindKey that would take the library and cell name of the current layout and create the verification directories required i.e. ~/verification/libName/cellName/lvs. What is the Cadence command to create a directory in UNIX? OR even better does anyone have something simillar already wrintten?
Secondly, I would like the assura form automatically open with the current layout Run Directories already loaded?  I have a bindkey to open the form and load the new Run Name (which is the cellName) but I am having trouble trying to automatically load the libName and cellName into the Run Directory path. Does anyone have the command to do this?
 I hope this is clear but please if you have any questions please let me know.
Thanks very much.
  • skillUser
    skillUser over 15 years ago
    Hi Patrick,
    I don't really work with Assura much, but I think that I can answer your first question - it seems that you are asking for a SKILL command to create a directory, if so the answer is simple, the command createDir() is the one that you want.  Just as Derek noted in an earlier (unrelated) post; I found this by typing "dir" into the Find/Search field of the Finder (SKILL Finder, cdsFinder) utility - one of the many results was "createDir" and clicking on it tells you that it creates a directory.  This can be obtained by typing "startFinder()" in the CIW, or by typing "cdsFinder" at the Unix prompt where the Cadence tools are set up to run from.
    Finder results:
    createDir(
      S_name
         => t | nil
    Creates a directory.
    If I get more time I will look into the other questions.
    I hope this helps!
    Lawrence.
  • Quek
    Quek over 15 years ago
    Hi Patrick
    I have modified one of my skillscripts to give the output which you have requested. Hope that the script can solve your problem. : )
    Best regards
    Quek
    procedure( vuiUserDefinedSetupCB(formHandle)
       let( (newDir libName cellName runType)
          if(formHandle->layoutSource->value=="DFII" then
             libName=formHandle->layLibrary->value
             cellName=formHandle->layCell->value
          else ;Stream/Oasis input
             libName="streamFiles"
             cellName=formHandle->layCellName->value
          ) ;if
          case( formHandle->hiFormSym
             (vuiLVSForm runType="lvs")
             (vuiDRCForm runType="drc")
             (vuiERCForm runType="erc")
          ) ;case
          unless( isDir("~/verification")
        csh("mkdir ~/verification")
          ) ;unless
          unless( isDir(strcat("~/verification/" libName))
        csh(strcat("mkdir ~/verification/" libName))
          ) ;unless
          unless( isDir(strcat("~/verification/" libName "/" cellName))
        csh(strcat("mkdir ~/verification/" libName "/" cellName))
          ) ;unless
          newDir=strcat("~/verification/" libName "/" cellName "/" runType)
          formHandle->runDir->value=newDir
       ) ;let
    ) ;procedure
    assuraSettings.il
  • Patrick1982
    Thanks for your help Quek, however, I am getting the following error:
    *Error* def: function is write protected and cannot be redefined - vuiUserDefinedSetupCB
     And I've edited your code a bit, can you see anything wrong with this?
    procedure( vuiUserDefinedSetupCB(vuiLVSForm)
          if(vuiLVSForm->layoutSource->value == "DFII" then
             libName = vuiLVSForm->layLibrary->value
             cellName = vuiLVSForm->layCell->value
          ) ;if
          case( vuiLVSForm->runsetField
             (vuiLVSForm runType = "LVS")
          ) ;case
          unless( isDir("/projects/Endeavour/poriorda/Cadence/verification")
        csh("mkdir /projects/Endeavour/poriorda/Cadence/verification")
          ) ;unless
          unless( isDir(strcat("/projects/Endeavour/poriorda/Cadence/verification" libName))
        csh(strcat("mkdir /projects/Endeavour/poriorda/Cadence/verification" libName))
          ) ;unless
          unless( isDir(strcat("/projects/Endeavour/poriorda/Cadence/verification" libName "/" cellName))
        csh(strcat("mkdir /projects/Endeavour/poriorda/Cadence/verification" libName "/" cellName))
          ) ;unless
          newDir = strcat("/projects/Endeavour/poriorda/Cadence/verification" libName "/" cellName "/" runType)
          vuiLVSForm->runsetField->value = newDir
       ) ;let
    ) ;procedure
    Thanks again,
    Patrick.
  • Quek
    Hi Patrick
    I think perhaps the cmd "sstatus(writeProtect t)" exists somewhere in your setup and hence is preventing a procedure from being redefined. Would you please restart Virtuoso and reload the edited file? It should be fine. The edits look ok
    Best regards
    Quek
  • Patrick1982
    Thanks very much for your help Quek and Lawrence.
    Here is what I have come with, I've created a skill file for each verification Run and I've assigned each run it's own Bindkey (F4-LVS, F5-DRC, F6-ANTENNA, F7-DENSITY) and the following is the code I've used.  Thanks again for your help.
    ibmPdkRunAssuraLVS()
       let( (libName cellName)
          ) ;if
        csh(strcat("mkdir -p /projects/Endeavour/poriorda/Cadence/verification/" libName "/" cellName "/lvs"))
       ) ;let
    hiiSetCurrentForm('vuiLVSForm) vuiLVSForm->runName->value = vuiLVSForm->layCell->value
    hiiSetCurrentForm('vuiLVSForm) vuiLVSForm->runDir->value = "/projects/Endeavour/poriorda/Cadence/verification"
    vuiLVSForm->fileSelector = t   vuiRcxFileSelect(?returnVar vuiLVSForm->runDir->value ?startingDir _vuiGetRunDirBrowsePath(vuiLVSForm) ?mode 'dirs)   vuiLVSForm->fileSelector = nil
    hiiSetCurrentForm('vuiRcxFileSelectForm)
    vuiRcxFileSelectForm->dirList->value = list(vuiLVSForm->layLibrary->value)
    vuiRcxDirDoubleCB(vuiRcxFileSelectForm)
    vuiRcxFileSelectForm->dirList->value = list(vuiLVSForm->layCell->value)
    vuiRcxFileSelectForm->dirList->value = '("lvs" )
    hiFormDone(vuiRcxFileSelectForm)
