  3. SKILL data structures
  • Views 18378
pran
pran over 15 years ago
I am new to skill.
I could see there are a number of functions like  "dbOpenCellViewByType" documented in  "SKILL Functions Reference". But I could not find the details for the various data structures used as output or input by these functions. For example, dbOpenCellViewByType returns a varible of type "dbObject". And I could not find the description of this varible type. If it is a structure, where are its members defined/declared. I could see c~>instances where cv is of type "dbObject", but what about other members.
Can someone point me to some docs for this?
    archive over 15 years ago
     I'm not sure where it's documented, but the piece of information I find most useful is that the ~>? operator can be used to interogate objects for their members. So in the CIW try:
     cv = dbOpenCellViewByType(...)
    cv~>?
    This should print the members of the cv object.
    Look in <ICinstDir>/doc/skdfref/skdfref.pdf in the Database Access chapter. There's sections at the beginning which describe the idea of database objects, and then tables in the "Description of Database Objects" section at the end of the chapter which list all the attributes.
    But using ~>? and ~>?? are a useful way to find your way around each object type.
  • pran
    Thanks Andrew and oojah for quick replies. I tried ~>? and ~>??, they are really helpfull. I was not aware of these opeartors (I can find them now in the sklanguser.pdf).
