  3. One bindkeys for performance of two functions
  • Subscribers 150
  • Views 7657
Slawa
Slawa over 15 years ago
Hello
For example there is some VerticalFixedMenu with a name the TEST
procedure(TEST_MENU()
hiDisplayFixedMenu(TEST
"top"
500
500
hiSetBindKey("Command Interpreter" "Ctrl<Key>p" "TEST_MENU()")
Whether it is possible that similar BindKey also closed the given window operating by a principle hiFixedMenuDown (TEST)?
Regards
Slawa
  • skillUser
    skillUser over 15 years ago
    Hi Slawa,
    I'm not quite sure of your question, but if I understand correctly, you are asking if it is also possible to close the Fixed Menu using a bindkey, similar to the way that the menu was displayed, if so then the answer is "yes".
    The reason I'm not sure of your question is that it would surely have taken less time to test the question that it must have taken to post it!
    Anyway, I built an example based on what you put in the post, and I was able to add another bindkey to close the menu:
    hiSetBindKey("Command Interpreter" "Ctrl<Key>o" "hiFixedMenuDown(TEST)")
    A bindkey can have two different bindings based on whether an enterfunction is running or not.  A bindkey can call more than one function or perform more than one action.  I could not find a function to test if a fixed menu is being displayed, but it is safe to call the hiFixedMenuDown() function even if the menu is not currently displayed.
    If I have misunderstood the question, can you please explain in more detail what the question is?
    Lawrence.
  • Slawa
    Hi, Lawrence
    I meant that the first pressing of a combination of keys displays given FxedMenu and repeated (in a case if the menu is already opened) it closes. The combination of keys is thus invariable. That is
    1) the first pressing = hiDisplayFixedMenu
    2) the second pressing (if the menu is already opened) = hiFixedMenuDown
    Regards
    Slawa
  • skillUser
     Hi Slawa,
    Ok, now I understand - this is possible but a little tricky.  Here's some code that I wrote and tested successfully:
    procedure(toggleTestMenu()
    let( (one two)
      if(boundp('TEST) && hiIsInstantiated(TEST)
      then
        TEST = 'unbound
      else
        one = hiCreateMenuItem(?name 'one ?itemText "One" ?callback "printf(\"One\\n\")")
        two = hiCreateMenuItem(?name 'two ?itemText "Two" ?callback "printf(\"Two\\n\")")
        TEST = hiCreateVerticalFixedMenu(
                  'TEST
                  list(one two) 2 1
        hiDisplayFixedMenu(TEST "top" 500 500)
      ); if
    ); let
    ); procedure
    Then your bindkey would just call the toggleTestMenu().  The global symbol holding the menu needs to be undefined using 'unbound because the function hiIsInstantiated() returns t as long as the menu has been instantiated (displayed) once, even if it is no longer currently displayed!  So the workaround is to recreate the menu each time it is needed.  The unfortunate side effect is that if the menu was dismissed using the automatically added "Done" button, you need to press the bindkey twice to re-display the menu again.
    I hope that this answers your question.
    Best Regards,
    Lawrence
  • Slawa
     Many thanks for the help
     It has very much helped
    Best regards
    Slawa
