  3. Mark net with stop layer
  • Subscribers 152
  • Views 16108
gparasiliti
gparasiliti over 15 years ago
I need to highlight all pockets tied to a net, I tried to use Mark net command, but I can't define a stop layer in the connectivity rules.
I define all rules to probe the net, but I don't know how to define a rule to avoid the probe when there is an overlap with a specific layer.
For example: I want to probe contact-nplus-epi, but if there is a poly between contact-nplus (contact-poly-nplus) the probe needs to be stopped. How may I define aconnectivity rule in the mark net? Is the mark net the correct function for my problem?
Could you help me?
Giuseppe
  • Quek
    Quek over 15 years ago
    Hi Giuseppe
    Marknet function from IC614 does has a stop layer function. Please press F3 to bring up marknet options form so that you can set a stop layer. This function is not present in IC5141.
    Best regards
    Quek
