  3. Is there a way to display the SKILL functions being invoked...
  • Subscribers 152
  • Views 17721
Is there a way to display the SKILL functions being invoked similar to an excel macro?
pfrankis
pfrankis over 15 years ago
Hi Guys,
 I find that the hardest part in programming with SKILL is to know the name of the function that you need to call.  Is there a way to display the underlying function being called when the user performs a certain action interactively?  I'm picturing something similar to the way Microsoft Excel Macros work.
 for example, if you don't remember how to create a new cell view.  You can click on the new cellview button in the library manager and the icfb would show the underlying function like this:
deNewCellView("test_lib" "top" "schematic" "schematic" nil)
may be I'm being too optimistic, but if this exists it would be really helpful to know about it.
 thanks in advance for your help,
Peter
  • lrl12skdev
    lrl12skdev over 15 years ago
     Hi Peter,
     One good way is to open your CDS.log file, much better with "tail -f CDS.log" so you can see the log being displayed like in real time. But As for me, I prefer to search in cadence SKILL pdf files for functions because the first method I think can only help you with interactive functions. The pdf files are already sorted depending on the nature of the function e.g design framework, composer, layout editor, techfile, etc. so it is easier and informative.
    BR -lrlsk
    Of course, there's no need to use "tail -f" on the log file - you can use the Options->Log Filter settings in the CIW to control which bits of the log file get displayed in the CIW.
    However, as Irlsk says, these primarily log the interactive interactions - which is fine in some cases, but otherwise you might want the procedural equivalent of a function - so for example, you might see deNewCellView() but in your program you might not want a window at all and so dbOpenCellViewByType() might be more appropriate. Such information won't be shown in the log file (or elsewhere), so searching the documentation (using cdnshelp is probably easiest) is the way to narrow down the functions needed. Or using cdsFinder to search for functions based on words that are in the function names.
    Best Regards,
  • pfrankis
    Great, thanks guys
  • skillUser
    skillUser over 15 years ago
     Hi Peter,
    Just in case you were not aware, the cdsFinder or "SKILL Finder" tool can be started from the CIW either from the menus Tools -> SKILL Development -> Finder, or by typing "startFinder()", or from theUnix prompt by typing cdsFinder.  It can be a bit of a guessing game sometimes, so you might need to try parts of a possible function name, for example, related to your case you might try "open" or "create" as part of the function name.  Also, if you have a copy of the SKILL Quick Reference Manual, this can be helpful to browse through, and the functions are organised into sections for a particular tool or function class, e.g. Schematic functions, Core SKILL functions.
    If you know the tool that you are working with, for example Schematics, you might guess that the function name begins with the "sch" prefix, or "le" for the Layout Editor, "db" for generic database functions, "ge" for generic graphics editor functions, "hi" for Human Interface functions (forms, menus, bindkeys etc.)  This approach does not always work, for example the function to open a cellview non-graphically is a db function rather than, say, an "sch" prefix function or "le" prefix function.  Another example might be selecting an object in a schematic (or layout) window; there are some "ge" prefixed functions for selection which are not tied to which tool is being used (symbol, schematic or layout windows).
    I hope that this helps.
    Best regards,
    Lawrence.
