  3. How to parse the contents of a file?
  • Replies 15
  • Views 30010
Messi
Messi over 15 years ago
Hi everyone,
    If for example i have some file say rules file with contents of file being : <ruleno.> <rule name> <value>.
   How to parse the contents of this file and store in  table format?
  Can i get code for this?
  Messi
    Hi Messi,
    Can you give an example of the file contents? In particular knowing the delimiters would help. Your description was not that precise...
  • Messi
    Thanks for the quick reply...
    I will set an example: infile("/messi/Exp/rulecheck.il") looks like
       R1A  POLY WIDTH 0.5
          R1B ACTIVE WIDTH 0.4
       R2A POLY SEP    0.25
            R2B ACTIVE SEP    0.75
       R3 POLY OVERLAP 0.6
    ie..<ruleno.> <space> <layername> <space> <type> <space> <value>
    So basically i want to read this file and use parseString and store contents in table.I understand that i have to use infile command and then parseString with "space".but i am not able to put all these into a code..also i would like to make it into a table with all the values read from the file. The table contents should be like:
             <ruleno.>     <layer used(eg:POLY)>  <type(eg:WIDTH)>  <value>
    So, basically if i feed my rules filename in the procedure i should be able to see its contents in an tabulated form.
     Messi
  • LeJonT
    LeJonT over 15 years ago
    Something like this would do..
     procedure( parseFile( ipFile )
      let( ( tokens table )
        table = list()
        fpFile = infile( ipFile )
        while( gets( line fpFile )
          tokens = parseString( line )
          tokens && ( table = cons( tokens table ) )
        ) ;while file
        close( fpFile )
        println( table )
      ) ;let
    ) ;procedure
     After saving the above code in a file, you need to load it in icfb.
    load( "parseFile.il" )
    parseFile( "int.txt" )
  • Messi
    Thanks LeJonT,
       It works but it returns the contents of file as list.Can i obtain each element of this list and outfile (instead of geeting it printed in CIW) it into another file say out.txt.
      my out.txt should look like in table form as,
       headers: <ruleno.>   <layername>   <type>    <value>
                       R1A          POLY           WIDTH      0.5
    Thanks once again for your help,
       Messi
  • LeJonT
    This would do it..
    procedure( parseFile( ipFile outFile )
      let( ( tokens table fpFile fpoutFile )
        table = list()
        fpoutFile = outfile( outFile )
        fprintf( fpoutFile "%-15s%-15s%-15s%-15s\n" "RULE NO" "LAYERNAME" "TYPE" "VALUE" )
          tokens && fprintf( fpoutFile "%-15s%-15s%-15s%-15s\n" nth( 0 tokens ) nth( 1 tokens ) nth( 2 tokens ) nth( 3 tokens ) )
        ) ;while file
        close( fpoutFile )
        close( fpFile )
      ) ;let
    ) ;procedure
    parseFile( "int.txt" "out.txt" )
     But, I'm little surprised about why you are using SKILL for a file operation!
  • Messi
    Thanks alot,
        i wanted to know how i can read any file and out it.i tried to code by reading file as u have written using infile then parsing it.To make table i was using makeTable commands and i was using car and cdr concepts to get the contents of my parsed file.But my code generateed errors...
    anyways thanx for the help,
      Messi
  • LeJonT
      You ofcourse can choose to use table, list or any datatype that suits the purpose. Here in this case, double list can serve the purpose. car and nth( 0 list ) are similar and car is much more efiiicient to.
    If you can post the code in here, we can try to see to the issues..
  • Messi
    Thanks for your help,
        This is working and able to write to outfile.But can i know how to do the same using makeTable command.ie..my input would be just a rule file with the format mentioned earlier.my output would be a SKILL table.
    eg: a = makeTable("myTable" nil)
         so when i say a[R1A] it should return a list as: ("POLY" "WIDTH" "0.5")
    Messi
  • dmay
    dmay over 15 years ago
    This is simple enough. Here is the original code suggestion with changes to make it store the data in a table:
        table = makeTable("ruleTable" nil)
          when(tokens
            table[car(tokens)] = cdr(tokens)
        ) ;while file
        close( fpFile )
        printstruct( table )
      ) ;let
    ) ;procedure
    Derek
  • Messi
    Hi Derek,
             Thanks for your help.But when my rule file have this
                         RULE NO.    LAYER       TYPE                    VALUE
                            R1A,          POLY,      POLY WIDTH,            0.5
                            R1B,          POLY,      POLY SPACING,        0.25
                            R2A,          ACTIVE,    ACTIVE WIDTH,        0.7
                            R2B,         ACTIVE,    ACTIVE SPACING,     0.3
    when i load the code the output would have on top of it the headers ie (RULE NO.,LAYER...etc). cdr would help me remove these headers right??the output is also found to have results with R1B occuring first then R1A.How can get the output in same order as in the input rule file??
