  3. Buttons - switches
  • Views 2552
Buttons - switches
Slawa
Slawa over 15 years ago
HI
How to create the button description, after pushing on which it changes color (picture). That is I have created two icons through
hiCreateColorArray
hiMatchColorByName
hiStringToIcon
The first of them is a "white square"
The second - a "white square with a tick"
Now I want to create the button on the basis of these icons that pushing it in a case if the icon - a "white square" it changed an icon for a "square with a tick", in a case if its icon - a" square with a tick" that reversely on an  "white square". I hope has clearly explained.
Well and at the same time I will ask as to describe such button as Virtuoso Layout Ediror-Options-Display-Array Display. That is the button the switch. And also how to create the button after pushing on which it it appears as though drowned (pushed) and repeated pushing it results it in initial position
 In advance thanks
Slawa
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     I've not played with icons or colors but here is how to switch the text on a button:
    procedure( testForm2()
    hiCreateAppForm(
       ?name 'myForm
       ?fields list(
                  hiCreateButton(
                     ?name 'myButton
                     ?buttonText "Off"
                     ?callback "toggleButton( myForm 'myButton)"
                     ; ?buttonIcon
                     ; ?showTextWithIcon
                     ?enabled t
                                            ; ?invisible
    hiDisplayForm( 'myForm )
    ) ; ** procedure testForm2 **
    procedure( toggleButton( formId fieldId )
      let((
              curValue curField )
        curField =  get( formId 'myButton )
        curValue = get( curField '_buttonText )
        if( curValue == "Off" then
           putprop( curField "On" '_buttonText )
        else
           putprop( curField "Off" '_buttonText )
        ) ; ** if curValue **
      ) ; ** let **
    ) ; ** procedure toggleButton **
    You may possibly be able to do the same when switching icons. Look at the properties on the button while the form is displayed:
    myForm->myButton->??
     There is a property _buttonIcon which you may be able to change. If not, you would have to make two buttons and toggle the invisible property on  each.
    Ted
