  3. Modify corner of rectangle
  • Subscribers 152
  • Views 17031
Zdeno
Zdeno over 15 years ago
Hi, is it possible to modify corner of rectangle by SKILL? I know just lehimodifycorner command that opens only form for modify corner, but I don't know how to modify corners without this form. Any suggestion? Thank you a lot. Zdeno.
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     A rectqangle is represented in the database by its bounding box, two points - lower left and upper right. Once you start modifying the corners, you have to create a polygon. This first involves turning the bounding box into 4 points:
    rectBBox = rectId~>bBox
    pointList = list(
                        car(rectBBox)
                        list( xCoord(car(rectBBox)) yCoord(cadr(rectBBox)))
                        cadr(rectBBox)
                        list(xCoord(cadr(rectBBox)) yCoord(car(rectBBox))))
    Then you manipulate this point list to create the corner modifications and create a new object - a polygon:
     newObj = dbCreatePolygon( cvId list( rectId~>layer rectId~>purpose pointList )
    You may want to copy over all the properties from the rectangle to the polygon.
    Finally delete the rectangle.
    Ted
    Ted,
    Actually I think he just wants leModifyCorner rather than leHiModifyCorner.
  • Austin CAD Guy
     Thanks Andrew,
    That is a command I did not know. I learn something new every day.
    However, you cannot use leModifyCorner inside of a pcell and have to do it the hard way.
     Ted
  • Zdeno
    Thanks you a lot
    I needed function  "leModifyCorner"
        id_rect1 = dbCreateRect(cv_id "Nimp" list(x1:y1 x2:y2))
        leModifyCorner( id_rect1 list(t t t t) nil 20.0 20 )
    Have a nice day.
    Zdeno.
