  3. How to create a pcell inside another pcell?
  • Subscribers 150
  • Views 6651
FormerMember
FormerMember over 15 years ago
Hai,
  Is it possible to generate a pcell inside another pcell.If so, can anyone tell how it is done.If possible please give example..It would turn be great help for me.
 C10
    Hi C10,
    Do you mean how to instantiate another pcell within a pcell? If so, you would use the dbCreateParamInst or dbCreateParamInstByMasterName function (covered in the documentation).
    Ah, hang on, that seems to be the same as your question http://www.cadence.com/community/forums/T/17369.aspx - so I think you're going to have to clarify what exactly you mean!
  • FormerMember
    Thanks Andrew,
       I got confused with the usage of the command.So wished to clarify with experts.
    Thanks for the help.
     C10
