  3. Error encountered during pcell instantiation??
  • Replies 24
  • Views 26590
Messi
Messi over 15 years ago
 Hai,
    This is the code i have written to read a file and then instantiate a pcell inside an already created pcell:
procedure(mypcell(ruleFile pcellInfo)
  let( (ruleFileTable purposeList mastercv inst )
  ruleFileTable  =  readFile( ruleFile )
;readFile is the function name for another procedure I created to read an file and drop its contents into a table
           foreach(line FileTable
           purposeList = caddr(line)
    ;the table has mainly four elements and I want the third element based on which instantiation has to be carried out
          unless(rexMatchp(pcellinfo purposeList)
           case(pcellinfo
             ("a"
         ;;To Create PCell for “a”
                    mastercv   = dbOpenCellViewByType("test" "pcell" "layout" "" "w")
                  ;mastercv is an already created pcell
                    inst           = dbCreateParamInst(
                                         "pcell" mastercv "a" list(0 0) "R0" 1
                                           list(
                                               list( "w"  "float" 0.5)
                                                );dbCreateParamInst
                                         dbClose(mastercv)
                                      ); for case “a”
           ("b"
;;To Create PCell for "b"
                                        "pcell" mastercv "b" list(0 0) "R0" 2
                                           list(
                                                list( "s"  "float" 0.25)
                                            );dbCreateParamInst
                                          dbClose(mastercv)
                                          );case
                                   );for case  "b"
                           );unless
        );foreach
    );let
);procedure
But i am generating errors while i run this code :
Can anyone look into and this find the error in it.....
  Messi
    Hi Messi,
    I don't understand. I explained how to give the width value - using cdfParseFloatString, so what can't you figure out?
    The case() approach I suggested handles both upper and lower case. It converts the name from the rule file to upper case using the upperCase() function, and then compares it in upper case. So it would do what you ask for.
  • Messi
    Hai,
       i understood i had to use atof since my values were in string.I was trying to tell that, in the first condition i gave the width as it is read from rules file.Now consider second condition when case is "SPACE" ie as per my code variable i will have rule no."R1B" (foreach loop i use so after carrying out "R1A" it will go to "R1B" or the next key),so in this second condition as per rule i can take value only as space which i feed inside list( "space" "float" nth(2 ruleTable[i])),but in the width section i want to give value as read from rule no. "R1A".
    ie   list( list( "w2" "float" "here value of POLY WIDTH as given in "R1A")
                list ("space" "float" nth(2 ruleTable[i]))
    This was the confusion i had in my mind on how to get the value..
    I have run the code as per your suggestions and able to get cellviews with names of rule no.But the instantiation is not done properly i feel as each of them is empty.
    I have pasted the code by which i created my intial pcell...which i instanstiate in the cellviews named as rule numbers.
                       procedure(masterpcell(cv type)
                         let( ()
                          case(type
                             ("WIDTH"
                                 rodCreateRect(
                                         ?layer   list(layer1 "drawing")
                                         ?cvId    cv
                                         ?width   l1
                                         ?length  w1
                                         ?origin  list(0 0))
                          ("SPACE"
                                   lay1Id = rodCreateRect(
                                                   ?cvId   cv
                                                   ?width  l1
                                                   ?length w1)
                                   lay2Id = rodCreateRect(
                                                     ?layer  list(layer2 "drawing")
                                                     ?cvId   cv
                                                     ?width  l2
                                                     ?length w2 )
                                    rodAlign(
                                                   ?alignObj lay1Id
                                                  ?alignHandle "lowerLeft"
                                                    ?refObj  lay2Id
                                                     ?refHandle "lowerLeft"
                                                      ?xSep -(space+l1) )
                    ("OVERLAP"
                            rodCreatePath(
                                         ?width l2
                                          ?pts list(0.0:0.0 0.0:w2)
                                          ?encSubPath
                                                     list(
                                                            list(
                                                              ?enclosure      l1
                                                              ?beginOffset   -overlap
                                                              ?endOffset     -overlap  )
                   );rodCreatePath
      );case
     );let
    );procedure
    ;;To Create PCell
                pcDefinePCell(
                       ;;Identify the target cellview.
                                 list(ddGetObj("lib1") "test" "layout"
                             ); end of list
                   ;;Declare parameter name-value pairs.
                                    (layer1 "POLY")
                                     (l1  0.5)
                                     (w1  0.6)
                                     (layer2 "ACTIVE")
                                     (l2  1.5)
                                     (w2  1.6)
                                     (type "WIDTH")
                                     (space 0.75)
                                     (overlap 0.5)
                       );end of parameters
                 let((cv)
                            cv = pcCellView
          );let
    ); end of pcDefinePCell
    Is this code wrong? But a generated pcell with this code and when i test by instanstiating this pcell by making new cellviews by going to library manager file>new>cellview it runs fine.But when instantiate the same inside the cellviews using dbCreateParamInst with cellview name "Rule no." i am getting empty set.Why is it so??Hope you got my problem.
    Messi
    Messi,
    This is getting rather beyond a bit of casual help; I'm getting close to having written the whole thing for you. Debugging code when you have not given all the pieces is rather hard. For example, I don't have parseFile, I don't have the latest version of your instPcell function  after the latest fixes. I might spot by inspection the errors, but without all the data, it is much harder and to be honest, I don't really have time given that I am doing this in my spare time (it's not part of my role at Cadence to answer things on this forum).
    If you want help, please attach (as an attachment) the entire code. That will at least avoid anyone having to invent the missing functions (which quite possibly are the reason for your problem).
    For example, I took the pieces you've given, and with some corrections to the arguments to dbCreateParamInst in instPcell so that the correct type of each pcell parameter were passed, I got the four cells created, each of which had some layout in. So the chances are that the problems are either in your latest version of instPcell or in parseFile (I just made a version of that up).
    If  you want to have the SPACE case reference the WIDTH case, I think you would need to store the rule information in such a way that you could look up the WIDTH rule for the same layer as the one you're on. This probably means multiple tables that you build when reading the file - one indexed by the rule name, and another which is a table of tables, indexed by the layer name, and then the rule type. Then you could do:
     ruleLookup["POLY"]["WIDTH"]
    or even:
     ruleLookup[nth(0 ruleTable[i])]["WIDTH"]
    to access the width rule for a layer when creating the SPACE instance.
    Anyway, I've already spent more time than I said I would on this, so back to the day job.
    Best Regards,
  • Messi
       Thanks Andrew and sorry if i had taken too much of your time.I am carrying on my debugging.My parseFile code was(just for your information):
    procedure( parseFile( ipFile )
      let( ( index Table rulesFile value key line ruleLookup)
       unless( ruleFile = infile( ipFile)
          error( "Cannot open file %L for reading" ipFile)
        ) ; unless
        Table = makeTable("My_Table" nil)
        rulesFile = infile( ipFile )
        while( gets( line rulesFile )
          index = parseString( line )
          when(index
            value = nil
     ;;Remove Headers of the rules file
            unless(rexMatchp("RULE NO" car(index))
              rexCompile("^ *")
              key = rexReplace(car(index) "" 0)
              foreach(col cdr(index)
                  col = buildString(parseString(col))
                  value = append1(value col)
              when(key && value
                  Table[key] = value
        ) ;while file
        close( rulesFile )
        ;;Return values and arrange table
        foreach(key sort(Table~>? 'alphalessp)
            printf("%s:  " key)
            foreach(col Table[key]
                printf("%-15s " col)
            printf("\n")
        Table
       ) ;let
    ) ;procedure
    Anyways thanks,learnt a bit of SKILL from you and this forum.
    Messi
