  3. Error encountered during pcell instantiation??
  • Replies 24
  • Views 26579
Messi
Messi over 15 years ago
 Hai,
    This is the code i have written to read a file and then instantiate a pcell inside an already created pcell:
procedure(mypcell(ruleFile pcellInfo)
  let( (ruleFileTable purposeList mastercv inst )
  ruleFileTable  =  readFile( ruleFile )
;readFile is the function name for another procedure I created to read an file and drop its contents into a table
           foreach(line FileTable
           purposeList = caddr(line)
    ;the table has mainly four elements and I want the third element based on which instantiation has to be carried out
          unless(rexMatchp(pcellinfo purposeList)
           case(pcellinfo
             ("a"
         ;;To Create PCell for “a”
                    mastercv   = dbOpenCellViewByType("test" "pcell" "layout" "" "w")
                  ;mastercv is an already created pcell
                    inst           = dbCreateParamInst(
                                         "pcell" mastercv "a" list(0 0) "R0" 1
                                           list(
                                               list( "w"  "float" 0.5)
                                                );dbCreateParamInst
                                         dbClose(mastercv)
                                      ); for case “a”
           ("b"
;;To Create PCell for "b"
                                        "pcell" mastercv "b" list(0 0) "R0" 2
                                           list(
                                                list( "s"  "float" 0.25)
                                            );dbCreateParamInst
                                          dbClose(mastercv)
                                          );case
                                   );for case  "b"
                           );unless
        );foreach
    );let
);procedure
But i am generating errors while i run this code :
Can anyone look into and this find the error in it.....
  Messi
    Hi Messi,
    Rather hard to debug when you didn't say what the actual errors where. However, a few comments:
    1. Not a good idea to have functions such as readFile, mypcell which don't have sensible prefixes - too much chance of clashing with other functions
    2. The code itself is not creating a pcell. Is this function called from a pcDefinePCell definition? Not obvious from the code above.
    3. The arguments to dbCreateParamInst are wrong - you are passing the first argument as a string "pcell" - it is supposed to be the cellView in which you are creating the instance
    4. You are opening the mastercv variable in "w" mode (this will overwrite that cellview), prior to trying to instantiate it inside "pcell" (whatever that is). This means you've just blanked out the master before trying to instantiate it. Surely you should be opening it in "r" mode?
    Best Regards,
  • Messi
    Thanks Andrew,
      i figured it out.As u mentioned one of the mistake was "w" mode which need to be changed to "r".Then i needed to get cellview db value instead of "pcell"...I have edited it..its working fine...
     Messi
  • Messi
           i am able to run the instantiation of pcell program...But i need some help in the command makeTable...I have asked the same in some other post..I am still finding trouble in understanding it.
    I would like  to know how makeTable works??what would be the output??How to access line by line contents of a table...If possible give example and explain..
     Messi
    Hi Messi,
    You can think of a table as a "hash table" or "associative array" as in other languages. The idea is that it allows you to have something like an array, except the index can be anything that you like. It could be a string, or a database object, or a list - whatever. Effectively what happens is that it encodes (or hashes) the key (the index), and then uses that to approximately address the entry in the table, and from there it can do a search to find the exact match (this is a very simplified explanation - you might want to look at http://en.wikipedia.org/wiki/Hash_tables for a bit more insight). The benefit of all of this is that it allows for a dynamic amount of keys - you don't have to pre-allocate space (like you would with a normal array), and it also has fast access (not quite random access, but not far off) compared with other dynamic structures such as lists (which are sequential). The downside is that the structure is unordered, and so whilst easy to visit all the keys in the table, there is no record of the order in which they were added.
    To illustrate it:
    myTab=makeTable("myTableName")
    Now, the first argument to makeTable is really unimportant. The only thing it serves is that the print representation of your variable myTab will now show:
    table:myTableName
    There is no requirement for the first argument to be unique - as all it is used for is the print representation as above.
    Having created the table, you can now add values into it:
    myTab[2]="test"
    myTab["hello world"]=198
    myTab[geGetEditCellView()]=car(geGetSelSet())
    myTab[list(1 2)]='someSymbol
    As you can see, the keys (the index in the array syntax) can be any data type, as can the values. You retrieve the values by using myTab["hello world"] (say) - giving the same key.
    If you try to refer to a key that doesn't exist (e.g. myTab[5]) it will return the symbol unbound. If that's not what  you want, you can choose when you create the table what value should be returned for any key that doesn't exist. So if I had done myTab=makeTable("myTableName" nil) it would have returned nil or if I'd done myTab=makeTable("myTableName" 0) it would have returned 0. Try this out yourself.
    Having built a table, you can visit the contents easily. With the above, for example, I could do:
    foreach(key myTab
      printf("KEY: %L  VALUE: %L\n" key myTab[key])
    and it would print out:
    KEY: db:0x12c31d92  VALUE: db:0x14a37532
    KEY: 2  VALUE: "test"
    KEY: (1 2)  VALUE: someSymbol
    KEY: "hello world"  VALUE: 198
    There is no guarantee what the order would be here, by the way. It would be consistent within a particular version, but you should never, ever rely on that.
    You can also find the keys by doing myTab~>? or the keys and values by doing myTab~>?? . tableToList(myTab) is another way of converting to a list of lists (like an "assoc" list structure).
    Here's an example (one we normally use in the training class):
    shapeTable=makeTable("shapeCount" 0)
    foreach(shape geGetEditCellView()~>shapes
      shapeTable[shape~>objType]=shapeTable[shape~>objType]+1
    foreach(shapeType shapeTable
      printf("%-20s: %d\n" shapeType shapeTable[shapeType])
    This will give an output something like:
    pathSeg             : 298
    path                : 36
    rect                : 2376
    Now, if you want to read something and keep track of the order, there's nothing to stop you doing this. If you have a file containing:
    RUL1 POLY1 WIDTH 0.1
    RUL2 POLY1 SPACING 0.5
    RUL7 METAL1 WIDTH 0.5
    RUL6 METAL1 SPACING 0.6
    I've kept it simple for illustration purposes. Then I read this:
    ; use a structure to bring together both the table and the order list
    defstruct(ruleData order table)
    ruleInfo=make_ruleData(?order nil ?table makeTable("ruleData" nil))
    prt=infile("rule.txt")
    when(prt
      while(data=gets(line prt)
        ruleList=parseString(line)
        ruleInfo->order=tconc(ruleInfo->order car(ruleList))
        ruleInfo->table[car(ruleList)]=cdr(ruleList)
    ; because using tconc to build list on order, convert to a normal list
    ruleInfo->order=car(ruleInfo->order)
    ; now print out the contents in order
    foreach(key ruleInfo->order
      printf("%s %s\n" key buildString(ruleInfo->table[key]))
    Of course, you can access an arbitrary rule easily using ruleInfo->table["RUL7"] say.
    Hope this helps!
    Best Regards,
  • Messi
    Hai,
      Thanks for the explanation.Explaantion was superb...i didnt know abt ~>? operator until u helped me out...Thanks 4 that....
    I am reading a rule file then make it into a table and based on the entry in table i create or instantiate a pcell inside another.ie..if the purpose in table i made is WIDTH it should be able to make a pcell for width case...similarly for others,for this i have written the code.
      procedure(instPcell(ruleFile libName @rest Info)
      let( (ruleTable  mastercv cvd)
         ruleTable = parseFile(ruleFile)
         mastercv  = dbOpenCellViewByType(nthelem(1 Info) nthelem(2  lnfo)
                       nthelem(3 lnfo))
         foreach(i ruleTable~>?
            cvd = dbOpenCellViewByType(libName ruleTable[i] "layout" "maskLayout" "w")
             cond(
                rexMatchp("WIDTH" nth(1 ruleTable[i]))
                dbCreateParamInst(
                        cvd mastercv ruleTable[i] list(0 0) "R0" 1
                 list(
                                  list( "width"  "float" 0.5)
                                  );dbCreateParamInst
                    rexMatchp("SPACING" nth(1 ruleTable[i]))
           dbCreateParamInst(
                           cvd mastercv ruleTable[i] list(0 0) "R0" 2
                                list(
                                       list( "space"  "float" 0.25)
                                );dbCreateParamInst
                        dbSave(cvd)
            (t println "Arg is an unknown type")
      dbClose(cvd)
      dbClose(mastercv)
        );foreach
      );let
    );procedure
    when i run this program as a whole the rexMatchp error is encountered...ie it says unbound variable rexMatchp..
    How to eliminate this error..Any changes i need make in code..pls tell..
     Messi
    Hi Messi,
    The problem is caused by the fact that each of the clauses in your cond is improperly formed. They should be:
    cond(
    (conditional_expression1 expr1 expr2...)
    (conditional_expression2 expr1 expr2...)
    In other words, you need parentheses around each clause, which you don't have. So it should be (apologies for the formatting; I'm replying via email on a handheld device):
             cond(
    ; missing parenthesis here
             dbCreateParamInst(
                 list(
                                  );dbCreateParamInst
    ; missing close parenthesis here
    And so on for each clause. Without this the rexMatchp part is being interpreted as a clause which looks like this:
    (rexMatchp "WIDTH" nth(1 ruleTable[i]))
    And so the rexMatchp is seen as a variable.
    Note too that you've done:
    It is completely unnecessary to use the squiggle here, as I showed in my last append. So this will do the job:
      foreach(i ruleTable
    Otherwise you create a list unnecessarily.
  • Messi
    Hai,
      yes...dat was the mistake...it was real blunder from my side.i want to use the rule no.s as my keys so used squiggle operator....Moreover i wanted the name of each instance to be keys or rule numbrs...
    Still i have run into some mre  issues...Will try 2 solve.....
    Thanks 4 d reply...
    Messi
    Hi Messi,
    There's no tax on characters in the forum, so please try to use fully formed words rather than text-speak. I tend to switch off when I see this as it is very hard to understand, and am much less likely to respond. English as a language has evolved over centuries to ensure that it can be comprehended easily. You're not tweeting to the forum, so any post doesn't have to fit in 140 characters!
    By the way, if you want the rule numbers to be keys, you still don't need to use the squiggle operator. When you do foreach over a table, it always sets the loop variable to each key.
  • Messi
    Hai,
      now error is shown as dbCreateParamInst : arg#1 should be a database object (type template = "" ) nil
      Why do i generate such error??using dbOpenCellViewByType and storing in cvd i would get the dbId right??
     Messi
    Hi Messi,
    It will return nil from dbOpenCellViewByType if it can't write to the specified cellView. Is it locked? Does it have write permission?
    I'm slightly confused as to the purpose of your code - you talk in the original post about instantiating something inside an already created pcell. Is that really what is happening? Or are you just calling this function (outside of a pcell) and expecting it to create some new layouts which have instances of some existing pcells?
    By the way, your code doesn't appear to save the cellView it opens in write mode - so once you solve this problem, you'd hit the issue that everything is being discarded.
