  3. How to add details into an variable??
  • Subscribers 152
  • Views 6871
FormerMember
FormerMember over 15 years ago
Hai,
  This question may luk strange but just i want to know if it is  possible.question wud be like:
eg: procedure(myTest( a b c )
      user shuld be able to put 6 inputs..ie...after load"myTest.il"
     we input :
      myTest( "l1" "l2" "l3" "l4" "l5" "l6" )
    such that a will have "l1" b will have "l2" but c should have a list of "l4" "l5" "l6"
    Is this possible??
     Maybe this is nonsense question,But if there is any solution please let me know....
 C10
  • berndf
    berndf over 15 years ago
     procedure( test( a b @rest c )
        printf( "%L\n" list( a b c ) )
    Bernd
  • Messi
    Messi over 15 years ago
    Hai,
       I think this can also be  carried out using @optional list(.......)
    Messi
    No it can't... if you want a variable number of arguments, you need to use the @rest form. The @optional allows specific additional arguments - so you could do procedure(myFunc(a b @optional c d) ...) which means you could pass from 2 to 4 arguments.
  • FormerMember
          Thanks everyone
    C10
