  3. How to use procedure inside pcDefinePCell??
  • Subscribers 150
  • Views 9898
FormerMember
FormerMember over 15 years ago
Hi ,
  Is it possible to create a pcell based on runnig of procedure?? I meant if the procedure has many conditions inside it, it should be able to produce pcell for each condition.
If calling a procedure inside a pcDefinePCell is not effective,then how can i link two codes.I meant i make a code using procedure(xyz(....))
in a code named myCode.il and in another code named myPCell.il i create pcells based on conditions given in myCode.il??
Can this be done??
C10
    Hi Carlton,
    Yes, you can do this. For example, here's an excerpt from a pcell definition done this way:
    * Function: *
    * AGDEdefinePC *
    * Arguments: *
    * [libName] *
    * Return Value: *
    * t *
    * Description: *
    * Create the pcell 'fingerCap'. *
    * By default the pcell will be placed in devlib library. *
    * If an other library is needed you only have to pass the new *
    * library name as parameter (it is optional). *
    * all pcell parameter are set to their default value. *
    * this code call the main function AGDEfingerCap which draw the *
    * entire fingerCap cell. *
    * Usage: *
    * AGDEdefinePC([libName]) *
    procedure( AGDEdefinePC( @optional ( libName "devLib" ) )
    ;; open the library ID
    libId = ddGetObj( libName )
    if(libName then
    ;; pcell Id setUp.
    cvId = pcDefinePCell( list( ddGetObj( libName ) "fingerCap" "layout")
    ;; default parameters setup.
    (startLayer "M1")
    (stopLayer "M2")
    (fingers "2")
    (fingerLength "10")
    (topBarWidth "")
    (calcTopBarWidth boolean "TRUE")
    (botBarWidth "")
    (calcBotBarWidth boolean "TRUE")
    (addPlate "none")
    (fingerSpacing "")
    (calcFingerSpacing boolean "TRUE")
    (fingerEndSpacing "")
    (calcFingerEndSpacing boolean "TRUE")
    (stretchMode "fixed")
    ;; Call the main function which the full Pcell.
    AGDEfingerCap(
    ?startLayer startLayer
    ?stopLayer stopLayer
    ?fingers fingers
    ?fingerLength fingerLength
    ?topBarWidth topBarWidth
    ?calcTopBarWidth calcTopBarWidth
    ?botBarWidth botBarWidth
    ?calcBotBarWidth calcBotBarWidth
    ?addPlate addPlate
    ?fingerSpacing fingerSpacing
    ?calcFingerSpacing calcFingerSpacing
    ?fingerEndSpacing fingerEndSpacing
    ?calcFingerEndSpacing calcFingerEndSpacing
    ?stretchMode stretchMode
    ?cvId pcCellView
    ) ; end AGDEfingerCap
    ) ; end pcDefinePCell
    dbSave( cvId )
    else
    ; lib dosn't exist, so wanr designer.
    warn( "Could not find library %s\n" libName )
    ) ; end if libName
    t
    ) ; end proc AGDEdefinePC
  • FormerMember
    Hai ,
        Thanks for the help.
    I also want to know if i could write codes in two separate files and then link them.I meant if i create a code
     example: procedure( myProc(....... ) and save as myProc.il and based on the conditions in myProc.il can i create pcells in another code? Example: i make pcells using pcDefinePCell( ......) and save in myPcell.il.
    Is it possible to link myProc.il and myPcell.il such that pcell in myPcell.il is created based on conditions in myProc.il? If its possible how to run these in separate files and link,if this is not pssible,please ignore my post.
     C10
    Hi Carlton,
    You can put whatever functions in whatever files you like. SKILL doesn't care - you need to load the files to use them though (e.g. using the load() function). Note it is possible to set up an autoload property so the source for a function is auto-loaded the first time you want to use it (search for autoload in the SKILL documentation). You don't need to "link" (whatever that means) the two files.
    So you can define a function in myProc.il and refer to it in myPcell.il - provided that the code has been loaded. One point I should make is that if you have your pcell code (within the pcDefinePCell macro) call auxilliary functions, those need to be defined (i.e. loaded) whenever the pcell is used. In the example I posted, I call a function AGDEfingerCap which was defined in a separate file; I just needed to ensure that all those auxilliary functions were loaded from the pcell library's libInit.il file (note you don't need to call the pcDefinePCell from the libInit.il file though, as the code for the pcell is stored within the pcell cellView once it has been created).
