  3. delete shape on the basis of coordinates
  • Views 15750
bloodwayn
bloodwayn over 15 years ago
hi
is there any way to delete a rectangle on the basis of the coordinates? so i know where the rectangle is but i can't find a function or so where i can say: delete the rectangle( or figure) on the position x,y (specially xMin,yMin xMax, yMax for rectangle).
so i wouldn't search the whole layout for all rectangles and compare the coordinates until i found the right one.
regards
philip
  • Zach
    Zach over 15 years ago
    I'm no expert here but it seems like DJSelectAreaPlus() should do the job.  Example:
    \a DJSelectAreaPlus()
    \i 0:12250
    \a addPoint(hiGetCommandPoint())
    \i 2500:19950
    Regards, Zach
    Hi Zach,
    That's not a Cadence function; I assume it's part of some customisation at your company. The way I'd do it is to use dbGetTrueOverlaps(cvId list(xy xy)) (where xy is the point you want), and then use dbDeleteObject() on the results. Or in a graphical environment you could do a selection (e.g. using a ge.*Select type function) and then delete the selected objects - but I'd go for a solution which works without needing the windows to be open to make it more flexible.
