  3. use of load in an procedure
  • Views 15966
The Consultant
The Consultant over 15 years ago
procedure( a()
let( (()
x= "input.il"
load x
 doesn't work, ERROR: *Error* eval: unbound variable - load
how to fix this?
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     Try:
    load(x)
     The parentheses must be included in code written in a file. You can get away with it interactively but not in a SKILL program.
     I always explain that SKILL has three function calling syntaxes:
    1. C-like
      myFunc(arg1 arg2 arg3)
    2. LISP-like
      (myFunc arg1 arg2 arg3)
    3. Lazy
    The "Lazy" syntax is fine whenever you don't need to use the return value of the function, which in practice means you cannot use it whenever the function call is surrounded by anything (including  procedure, let etc). In practice I always explain when teaching that this should be used for quick (lazy) typing in the CIW only.
  • The Consultant
     sometimes it's so easy ;-)
