  3. How to prevent duplicate cell creation?
  • Views 16233
kumarb
kumarb over 15 years ago
Hi Experts, I wrote the following SKILL to prevent duplicate cell creation while creating new cell in any of the project library.==============================procedure(DuplicateCellChk(@rest args) let((libList libName cellName tmpPath (cells_with_same_name nil))    if(car(reverse(args))=="ddViewType"   then  tmpPath=cadr(args)  libName=car(args)~>lib~>name  cellName=car(parseString(tmpPath "/"))  libList=ddGetLibList()    ;;ignoring lx*SCRATCH  temp cells   if(!rexMatchp("^lx[a-zA-Z0-9]*SCRATCH$" cellName)  then    foreach(lib libList     if(member(cellName lib~>cells~>name) then      cells_with_same_name=cons(lib~>name cells_with_same_name)      );if    );foreach   ); if SCRATCH cell check    if(length(cells_with_same_name)>1 then    if(ddGetObj(libName cellName)~>views then         hiDisplayAppDBox(                    ?name gensym('dialogBox1)                    ?dboxBanner "Warning!"                    ?dboxText  strcat("Duplicate cells exists with the name " cellName " in Libraries " sprintf(nil "%L" cells_with_same_name))                    ?buttonLayout 'Close                        );DBox                          else  ddDeleteObj(ddGetObj(libName cellName))     hiDisplayAppDBox(                    ?name gensym('dialogBox1)                    ?dboxBanner "Error!"                    ?dboxText  strcat("Can't create cell " cellName " as this already exists in libraries " sprintf(nil "%L" remd(libName cells_with_same_name)))                     ?buttonLayout 'Close                        ) ;DBox       error("\n")    );if   );if  );if t ) ;let);procddRegTrigger("PreCreateObj" 'DuplicateCellChk)========================================== This code works as far as cell creation is concerned. But, this is causing problem while instantiating pcells in the layout since function is being triggered on each object creation due to PreCreateObj. So, when I try instantiating pcell, submaster is created in VM and hence function triggers. So, this is not a practical solution. I only want to put check at the time to cell creation not all other object creation.  I need to put this check since out verification scripts expect unique cells in all the cds.lib. Do we have hook called PreCreateCell? Thanks in advance for the suggestions. Best Regards,Bhupendra
    Hi Bhupendra,
    Code formatting/line-wrapping makes it impossible to debug. I suggest you compare against the cellName being "^zpcell.*" or "^zvia.*" to filter out the pcell ghost scratch cellViews. You should also be able to limit the check when  just a ddCellType is being created, but can't really see your code to make clearer  suggestions.
  • kumarb
    I'm really sorry about formatting. I'll make sure about this in future. (It is my first post after Cadence :))
    I tried as suggested but somehow, not able to make it working.  Please let me know your expert suggestions:
     procedure(MiDuplicateCellChk(@rest args)
        let((libList libName cellName tmpPath (libs_with_same_name nil))
         if(car(reverse(args))=="ddCellType"  then
              tmpPath=cadr(args)
          if(and(!rexMatchp("^lx[a-zA-Z0-9]*SCRATCH$" cellName)
                   !rexMatchp("^zpcell.*" cellName)
                   !rexMatchp("^zvia.*" cellName))    then
             foreach(lib libList
                       libs_with_same_name=cons(lib~>name libs_with_same_name)
                          );if
                   );foreach
           libs_with_same_name=cons(libName libs_with_same_name)
           if(length(libs_with_same_name)>1 then
            hiDisplayAppDBox(
                        ?dboxText  strcat("Can't create cell " cellName " as this already exists in libraries " sprintf(nil "%L" remd(libName   libs_with_same_name)))
           ) ;DBox
        error("\nnoooooooooooooooooooooo\n")
          );if
       );let
      );proc
    ddRegTrigger("PreCreateObj" 'MiDuplicateCellChk)
  • kumarb
    I'm able to filter out pcell ghost scratch cellViews successfully after following your instructions. I had to use only "ddViewType" and delete the cell later in case of duplicates. With "ddCellType" it's not existing (even if I use error() ) and is going ahead with cell creation.
    Thanks for your help.
    Best Regards,        Bhupendra
