  3. Param section of Instantiated Pcell!
  • Views 15465
Messi
Messi over 15 years ago
   I writting SKILL code to instantitate a pcell into another cellview.The code i have posted in my previous posts.I am able to instantiate the master pcell into my cellviews based on conditions i needed,but problem i face is in the paramter section.
In the master pcell i have 15 parameters passed in the formal argument section.While i instantiate this pcell using dbCreateParamInst inside the list( list( {i pass only 3 parameters} ie
    dbCreateParamInst(
       cvd mastercv i list(0 0) "R0" 1
  list(list(  "width"      "float"      atof(nth(2 ruleTable[i])))
       list( "layer1"   "string"   nth(0 ruleTable[i]))
       list( "TYPE"     "string"   nth(1 ruleTable[i]))))
But i find that the new cellviews with the instants of mastercv has 15 parameters whereas i need only 3.
How can make so??Hope you got my problem!
Messi
    Hi Messi,
    The number of parameters is defined by how the pcell is defined. Any parameters not passed will pick up the pcell default. If you look at inst~>prop~>?? you should only see the three parameters you specified in the call - so what leads you to believe there are 15?
  • Messi
       Yes as you told,if i see the prop~>?? of the instantiated cellviews its returning me 3 parameters.this i checked by executing line by line ie first making mastercv then cv and then storing i  = dbCreateParamInst(..................),and when i use i~>prop~>?? it gives me 3 parameters prop.But while i go to cellview and select it and click properties->parameters it displays me all the parameters present in the mastercv.
    If my question is not sensible...Please Ignore!
    Messi
  • Messi
       Ignore my previous post.Now i understood what you meant.Sorry for that post.
      Thanks for sparing your precious time. :-)
      Messi
