  3. Virtuoso crash with error message "The reported error is...
  • Subscribers 150
  • Views 4173
Virtuoso crash with error message "The reported error is : St9bad_alloc"
kbhow
kbhow over 15 years ago
My vrituoso sesion keep crashing when i trying to edit in Full Chip Level. Below is the error message, does anyone knows what the root cause for this. If memory is the main cause, how can i solve it.
Your advice and suggestion is much appreciated. Thanks
\# Memory report: now 3921764352 (0xe9c16000) bytes, UTC 2010.12.09 04:16:17.909 \# test ***warning***: memory usage seems to be dangerously high.
\w *WARNING* (GE-2012): An unexpected system error occurred in function geiDrawMultiLevels.
\w The reported error is : St9bad_alloc.
\w Contact customer service to investigate this issue.
\a hiDBoxOK(SPNlFpChkPinWarning)
\# Memory report: now 3921797120 (0xe9c1e000) bytes, UTC 2010.12.09 04:47:43.157 \# test ***warning***: memory usage seems to be dangerously high.
\r t
\o INFO (DB-170018): (dbPanic) dumping stack \o virtuoso has encountered a fatal internal application error and will now exit.d_alloc
-- How
    How,
    It appears to have run out of memory. Did you try running in 64 bit mode (eg "virtuoso -64" if running IC614)? Or try doing what it says in the log and contacting customer support?
    Reagrds,
  • kbhow
    Thanks.
    Yes, even after i set to run in 64BITS, Virtuoso still crashing frequently with this error message (2-3 times a day). My current machine has 16G memory, there should be no problem in accessing the memory right?
    -- How
    Hi How,
    That's right. Can you monitor the memory consumption - maybe there's a leak, or you genuinely are using a lot of memory still.
    Worth trying with the latest IC614 hotfix too, in case it's a problem that has already been resolved.
