  3. Decending into a bus of schematic instances
  • Views 14792
menime54
menime54 over 15 years ago
When decending into a bus of schematic instances, a popup box appears so that you can choose which instance you want to descend into.  Is there a way to code in our decend function to bypass or hit enter automatically on the box so that the function instantly decends without the box popping up??  Thanks.
    This is answered (or at least explained) in this post: /forums/p/16291/554097.aspx#554097
