  3. search for anything
  • Views 18826
search for anything
bloodwayn
bloodwayn over 15 years ago
 hi
i have a short question. is it possible to search a list for any entries. it's a little bit difficult to describe. so in if you use the searchfunction in windows, you can type " *.mp3 " to search the directory for all mp3 data. and there are something like this in cadence? i want to search all cells in a library which begins with "top" for example. and the function should found all cells like "top_1" "top_2" "top_hello" or so, for example.
so i hope you can follow my drifts.
regards
philip
    Hi Philip,
    In IC61X, you have the search assistant. This is under Windows->Assistants->Search and it allows you to do this kind of search.In IC614, it's  in Virtuoso Layout Suite L, and Virtuoso Schematic Editor XL (in IC615 this is waterfalled into VSE L).
  • bloodwayn
    hmm ok thanks. but that's stupid^^
    i have version 5.10. so i must find an other solution
    regards
    philip
  • dmay
    dmay over 15 years ago
    I'm not sure what kind of result you want, but here are two ways to do it:
    lib = ddGetObj("myLibrary")
    topCellNames = rexMatchList("top*" lib~>cells~>name)
    topCellIds = setof(x lib~>cells rexMatchp("top*" x~>name))
    Also, in the Library Manager, under the View menus is something called "Filters". Enter "top*" as the cell name filter and the library manager will only show you cells that match that filter.
    Derek
    I'm not sure what is "stupid" about this?
  • bloodwayn
    hey andrew,
    stupid is perhaps the wrong expression. sry it might come across wrong.it should sounds like angrily, cause i have the version 5.10 and not 6.1 ;)
    hope you can follow on my drifts
     @derek: thanks i will test it
    regards
    philip
